Grading Kubota L 5740 for grading tractor
   / Kubota L 5740 for grading tractor #11
What are you doing with it? Fuel use is completely dependant on use. My L5030HSTC uses 10 l per hour (about 2.75 gph) on the snowblower or other high load. It drops way back proportional to load.
My 100 hp tractor uses 5 gallons per hour on the discbine working hard. About proportional.
I really like my L5740 even though I am having some issues with loader capabilities.
unless you need the PTO hp a lower hp grandL might get better fuel usuage. I am getting about 3.5 gph and not running at PTO speeds. Coming from a older gas tractor I thought the diesel would be better on fuel NOT!!
   / Kubota L 5740 for grading tractor #12
As stated nothing but puttering around digging post holes, some mud lot cleaning , spread 18 ton 411 limestone, 2 hrs with bush hog clipping weeds. All told I have 27 hr on it now filled it up three times with 10 plus gals each time currently full Another TBNer with the same make/model MharryE actually has found our engine is rated at 3.7gpm in industrial trim and he confirms my estimate of fuel usuage, I think 4shorts might agree too
   / Kubota L 5740 for grading tractor #13
A 5740 is a nice tractor. I run Deere because their dealer network/support is far superior to any other in my area. I've had many Deere through the year and love them all. If I had better dealer networks for other companies I'd be over there to but Deere is head over heals in front of them all. No doubt Kioti/Bobcat/Kubota all make excellent tractors and for grading they will all be nearly equivalent. I'd buy from the dealer that treats you best.
   / Kubota L 5740 for grading tractor #14
Just the other day I was telling a buddy of mine that my new 5740 is a little easier on fuel than the 4240 I had. Might be because it's not working as hard :confused: I've been watching my fuel as well and just pushing snow without using the blower I'm running 1.25 GPH with the tractor in high range all the time. I think it's good. That being said the tractor is not close to working hard.
   / Kubota L 5740 for grading tractor #15
I just reworked the numbers and I'm burning 2.0 GPH with the 5740. :ashamed:
   / Kubota L 5740 for grading tractor #16
The 3.7 gpm is what Kubota publishes it running at peak power. That's what I get plowing where I hold it at 3700 rpm by varying the pedal (wish they had a cruise control for this - maybe next gen). I use a lot less mowing or moving snow, other jobs like that.
   / Kubota L 5740 for grading tractor #17
I'm not an expert on Kubota's but they don't have cruise control? Guess it's not a huge feature I think I've used it all of once or twice on my JD - I don't do a lot of mowing and more loader work - but it seems like they'd offer it:confused:
   / Kubota L 5740 for grading tractor #18
3700 RPM :shocked:
The RPM gauge on my 5740 only goes up to 3400 RPM. I don't even know if mine would go that high! I adverage 2400 RPM and its wound up pretty good then :confused: man if mine ever hit 3700 RPM it would be leaving the earths atmosphere. :eek:
Oh and there is cruise on the Grand L series tractors.
   / Kubota L 5740 for grading tractor #19
Yes they have cruise control on all GL models and some Lxx00 standard or as an option. I use mine a lot.
   / Kubota L 5740 for grading tractor #20
That's what I would have thought. I must have been reading the post wrong.
2008 GMC C7500 Altec LRV55 55ft Forestry Bucket Truck (A50323)
2008 GMC C7500...
2022 Ford F-550 Cab and Chassis Truck (A50323)
2022 Ford F-550...
New Kivel Single Skidloader Spear (A50774)
New Kivel Single...
CATERPILLAR D6 LGP HI-TRACK CRAWLER DOZER (A51242)
CATERPILLAR D6 LGP...
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
