Kubota L 3350 won't budge
   / Kubota L 3350 won't budge #1
mickeynsac
Isleton,CA
L3350 Kubota
We have a Kubota L 3350 that has been sitting for 6 months. Finaaly got it to run, raise & lower bucket, PTO bush hog fine but we can't get it to move forward or back. It has a forward / reverse shifter on column but does not seem to make a difference.
HELP we have 24 acres to mow and very desperate.
   / Kubota L 3350 won't budge #2
My Kubota L4330 GST came to a stop once while bush hogging and would go no further. I think the motor still ran but not sure. Turns out something I drove over disconnected a wiring harness connector under the tractor-maybe toward the rear of the tractor. Snapped it back together and it was fixed. Also, it showed an error report on the dashboard display.
   / Kubota L 3350 won't budge #3
I have an L3450 with the shuttle shift that might be similar. Check the levers on the left fender, that is one for HI/LOW range with a neutral and one for 2 Wheel/ $ Wheel driver again with a neutral. - So there are three ways to put the tractor into neutral.
carl
OK it was the 2 speed selector left of seat. Thanks for the tip!
Got the tractor to move but has no power. When I let out the clutch it will go for about twenty feet and then starts to die. I stop let RPMs rev up , let out the clutch and it dies.
We have cleaned tank, fuel lines, installed new filter and replaced transfer pump.
carl
   / Kubota L 3350 won't budge #5
I have the L3450 also. Sounds like you need to bleed the injectors - over and over again, then some more. Changing fuel filters is **** on getting air in the system.
JOHN DEERE 17P LOT IDENTIFIER 226 (A53084)
JOHN DEERE 17P LOT...
JOHN DEERE 1700 (A53084)
JOHN DEERE 1700...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
2009 CASE IH3406 - 6R36" CORN HEAD (A51247)
2009 CASE IH3406 -...
