kubota L 275 no fuel to injectors...
   / kubota L 275 no fuel to injectors... #1
calfal
lake charles,la.
kubota l275 power king 14/24 kioti ck27
I recently picked up another kubota L 275 .. was supposed to be running when parked.. was told the starter was locked up, knowing that I tore starter apart and was worst than I thought ended up with new starter..while I was was waiting for starter to come in I drained fuel tank,, washed twice and dried it ,, believe or not there were some twigs small branches inside the tank,, took a while to fish them out.. new filter and new fuel lines to the injection pump.. starter come in and I installed it..bleed the fuel line unto the injection pump.. then started to bleed injectors tried several times but no fuel to the injectors.. so I been looking around and the internet says the injector pump slide to stop the fuel flow to injectors may be stuck.. makes since being it has been parked for a while.. do y'all have any other suggestions to look at before I try to pull the injector pump... thanks in advance for any help or suggestions.. c falcon
MLE 4188CR Clean Room Scissor Lift (A49346)
MLE 4188CR Clean...
2005 Ford Expedition (A47371)
2005 Ford...
Salt Dog Spreader (A49251)
Salt Dog Spreader...
2011 Ford F-250 Crew Cab Pickup Truck (A46684)
2011 Ford F-250...
2019 Ford Explorer AWD SUV (A46684)
2019 Ford Explorer...
EZGO (A46684)
EZGO (A46684)
