Kubota KX161-3 Stabilizer Blade
   / Kubota KX161-3 Stabilizer Blade #1
tfordala
anniston,al
internation 464
I have a Kubota KX161-3 Mini Excavator...When I lower the blade to stabilize the machine it will pick the machine up..I let go of the blade handle and the blade releases and cant hold the machine stabile..Push the handle to lower it again and blade lifts machine..let go of handle and machine drops..Has anyone has this issue with the Kubota machines? I am not sure if its a cylinder or valve somewhere.
   / Kubota KX161-3 Stabilizer Blade #2
I assume the blade lever has a linkage. I would look there and make sure its centering properly.
1985 International X Con Semi (A50514)
1985 International...
2014 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2014 GENIE...
2014 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2014 Ford F-550...
2012 PETERBILT 367 (A50854)
2012 PETERBILT 367...
2017-2023 Ford Super Duty 4x4 Pickup Truck Bed (A49461)
2017-2023 Ford...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
