Kubota KX033-4 Thumb will not retract
   / Kubota KX033-4 Thumb will not retract #1
m7040
Elite Member
Frederick maryland
Kubota M7040, MF 203 industrial, ZD331, RTV 1100 , Kubota Minix excavator, Unimog 404
The thumb will clamp down but will not retract. Wondering if someone could help with best way to trouble shoot?
   / Kubota KX033-4 Thumb will not retract #2
Do you have a splitter valve for the thumb that could have gotten bumped ?
On excavators it is not done with splitter valves
   / Kubota KX033-4 Thumb will not retract #4
If that machine has both 1 way and 2 way flow to the auxiliary lines make sure you’ve got 2 way selected. If it inadvertently got 1 way flow selected theirs your issue
   / Kubota KX033-4 Thumb will not retract #5
Reverse the lines ,this will check if it’s fittings or valve or cylinder
   / Kubota KX033-4 Thumb will not retract #6
This is the first thing I'd check too.
JOHN DEERE 8R 340 LOT NUMBER 96 (A53084)
JOHN DEERE 8R 340...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
SHOULE RM8080 LOT NUMBER 129 (A53084)
SHOULE RM8080 LOT...
2016 HINO 268 26FT BOX TRUCK (A52141)
2016 HINO 268 26FT...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
