Kubota KX 151 Locked Hydraulics Help needed
   / Kubota KX 151 Locked Hydraulics Help needed #1
Jacks
Hello all.
I have been left my dads 95 model KX 151 and have some how locked the hydraulic that controls the arm.
In the past I would just ask my dad but he has passed away from asbestos cancer and I'm left in a bind.
I was operating the machine and suddenly the hydraulic to the arm locked, similar to the safety lever when dis-engaged when leaving the cab.
The problem has happened to me in the past but my dad always said I had hit the foot lever on the floor that switches the Boom swing to Machine swing.
I never actually seen how he activated the arm/bucket.
Every thing else on the machine works , blade up and down, tracks etc but nothing happens when moving the controls for bucket.
I have moved the boom/machine swing lever in all directions but still nothing.
Is there a trick to re-activating the bucket hydraulic again or is some thing else creating the problem?
Thanks
Jack
   / Kubota KX 151 Locked Hydraulics Help needed #2
I can't say for sure what's wrong with your machine but I had a hydraulic failure in my KX41 that was caused by a mouse chewing threw a wire. I found the break fixed it and everything was fine.
Hi
The machine has done this a number of times when I was operating over the last few years and it had some thing to do with the boom lever on the floor each time.
This time when operating I looked down and I had my foot resting on the lever while operating when the machine just stopped.
I was in mid air with a bucket of soil and the lot just locked.
I was able to walk the machine and operate blade but arm was locked in mid air.
I have removed all the plates/covers and seat and every thing and looks to be intact.
My thought is it might need to have a lever positioned in the correct area while positioning the boom/machine swing foot lever to the correct position to release.
hhmmm:confused::confused::confused:
2004 Hydraulic Breaker Excavator Attachment (A52377)
2004 Hydraulic...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2014 FREIGHTLINER CASCADIA SLEEPER (A54313)
2014 FREIGHTLINER...
2018 PINSA 130BBL VACUUM TRAILER (A53843)
2018 PINSA 130BBL...
2021 HAMM HD+9I VO SMOOTH DOUBLE DRUM ROLLER (A52706)
2021 HAMM HD+9I VO...
