Comparison kubota/ kioti specs and experience
   / kubota/ kioti specs and experience #71
All I can add is I bought my Kioti DK 35 w/KL 1450 loader new in 2001.
I just felt the quality/fit and finish was right on par with the other tractors I was looking at, at that time (other runners up were the John Deere 4400 and Kubota L 3410)
But had a lot more standard features . (foldable ROPS, mid PTO, draft control, rear remotes, extendable lower link arms , extendable sway bars, rubber floor mats, tilt steering, Etc.)
$16,995 which also included the SSQA and heavy duty bucket (which was an option at the time)
After 18 years and 2200+ hours I have never regretted that decision and would purchase the same tractor if I had to do it all over again.
It has been an excellent/reliable tractor for me.
   / kubota/ kioti specs and experience #72
I will agree with you on the "standard equipment" offered as actually being part of the tractor. I don't understand why Kubota can't or won't do that on their Standard L's. I asked for the extendable lower link arms for my 3301; the dealer said it was virtually impossible and cost would be ridiculous. It wasn't a deal breaker for me, but I can see how it might be for someone else.
   / kubota/ kioti specs and experience #73
Just so everyone knows, I don't hold any animus against Kubota tractors. My only point was that new guys often make comparisons that are not valid between brands. Yes my L3400 had a "jerky" 3pt like all L3400's have. Yes Kubota makes these tractors to a weight and price point. They are very popular tractors for these reasons. The Regional Kubota rep was actually right when he told me "if you wanted a 3pt like a Grand L you should have bought a Grand L" There is a REASON they make Grand L's and it isn't just "bells and whistles".
Grand L's are their premium line of tractors costing thousands of dollars more than so called "standard" L's. But if you buy a Standard L and think you are somehow getting a better bargain and only missing "bells and whistles" you are fooling yourself. If you are satisfied with a lighter tractor, with a 3pt that is not as smooth as it could be with lift capacities that are not as high, and with not as many features that make hitching up as easy, and without standard SSQA (an option on most), no standard remotes, and made to a price point more in line with your budget, then that is great. Both you are Kubota corporation are satisfied.
As for other emerging brands of tractors like my Kioti and LS etc, these tractors may be made in countries with wages lower than Japan, and also have aggressive marketing campaigns to try to win some market share away from the two big players in the compact tractor market here in North America, John Deere and Kubota. So yes you can buy "more tractor" for "less money" as compared to those two. Of course the dealer network even now is not as near as extensive as Deere and Kubota. Although my local dealer for Kioti is large and has an extensive selection on their lots. My current tractor was sold in the price range of a Standard Kubota L tractor and has features near that of the Grand L series.
One feature missing from my Kioti from a Grand L is the Grand L's excellent HST+ transmission. If you don't know what that is or the features it brings to the table, you can google it or see it in action on you-tube. Again no standard L has a HST+ transmission either. There are trade off's in any tractor buying decision. If you would like to know more of my knowledge of tractors, just ask me! :) I am willing to share...
You and I have had this conversation before James. I went with the MX and L strictly for the gear drive option. I sold my B2320 HST last summer because I just hated that tranny...
   / kubota/ kioti specs and experience #74
just saying my 5 year old could have told me something informative then you did. simple minds I guess, simple minds
I'd forget about me and concentrate on teaching your 5 year old correct grammar... Looks like he will need it. :confused3:
   / kubota/ kioti specs and experience #75
Do you think he'll be able to teach his kid how to use a comma in a sentence with independent clauses? What about appropriate use of an ellipsis?
   / kubota/ kioti specs and experience #76
:rotfl: I give, I know when I'm busted... Or do I ??? :cool2:
   / kubota/ kioti specs and experience #77
OOOOKAAAY. Speaking of things I don't know huh?.. Your just digging a hole deeper my friend. See the spec sheet below. By the way the 3pt knob right under you seat has NOTHING to do with making the 3pt lift smoothly. It is the drop rate control that allows fluid from your 3pt. cylinder to drain back into your "tank" which is the transmission cavity of your tractor. When I spoke of the Standard L Jerky hitch I was referring to the MLS valve of the 3 point itself NOT the drop rate control which is nothing more than a bleed valve. Your 3pt drops TOTALLY under the influence of gravity and nothing else. All you are doing when you are adjusting that valve is adjusting the rate that the fluid drains, or if you turn it all the way to the right it totally blocks the flow of the fluid. This is useful for transporting a heavy implement on a bumpy road with less stress on the 3pt.
I DID NOT make the comment directed to MR WOLFE about brain rot. I am innocent I tell ya.
AS the highlighted text shows. below the TOTAL flow of the Hydraulic implement pump. However like almost all of the rest of them it is divided into two sections. One section is dedicated to the power steering which is just over 5 GPM and the second sections flows first to the loader and then out the power beyond connector to the remotes (OF WHICH ALL of the DK series is by default equipped with one, which is another benefit of a Kioti and a KUBOTA Standard L is equipped with ZERO by default) and then on to the 3pt. The DK35se (my tractor) is just slightly under 10 GPM, which compares to the about 6GPM for the L3400 Kubota it replaces. Almost ALL compact tractors work this way,
I Don't know why anyone would want to argue about the Kubota I had and the Kioti I have now. There is NO question about the FACTS I stated about the Kioti having more fluid flow, more weight, heavier axles and many many more features for about the same money as a Standard L tractor. (I gave $19,200 including the sun shade) These are just facts they are not debatable. HOWEVER as I pointed out in my first post, we are comparing apples and oranges here. Or oranges and oranges :). The Standard L tractors even though the horsepower is comparable, the Kioti is built more like the GRAND L series of tractors and do not directly compete against Standard L tractors. They compete in SOME peoples minds that create spreadsheets and lists. The WHOLE point of my post was to say that these list's that newbys create DO NOT tell the whole story. MANY things are missed or not understood. For example in comparing loaders. etc. Most Newbs don't understand the importance of telescoping lower links and sway bars either until they have cussed and hooked up their implements a few times. I DIDN'T either. This is my 5th tractor. I have made some "dumbazz" tractor choices in the past.
Digging my hole deeper? You must have delusions of grandeur. You're the one digging a hole by saying a spped control has nothing to do with smoothness. That's literally what it's for, to allow your heavy implements to drop down slowly and smoothly if desired. Do you know anything at all about hydraulics? There are flow controls, there are no "smoothness" controls. Flow controls are what control the rate or speed and thus the smoothness of the motion. You're welcome.
About that pump capacity, does that include power steering also? Or is that separate? Do you know?
   / kubota/ kioti specs and experience #78
Take the disparaging remarks elsewhere. This is supposed to be an informative discussion. I have learned a ton from TBN but having to wade through internet warrior diatribes makes it much more difficult to find answers, facts, and (relevant) opinions.
   / kubota/ kioti specs and experience #80
Dude... come on. This is a help forum, not your mechanic's garage. No charge means the advice is worth what you pay for it. James is a good guy with a ton of knowledge that he is gracious enough to share with the rest of us, and thankfully so. You are out of line.
Bucket (A55973)
Bucket (A55973)
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A56435)
2023 Kubota...
2023 Sundowner Rancher Express 24FT Livestock Trailer - All-Aluminum Stock Hauler (A55302)
2023 Sundowner...
2015 Goose Neck Cattle Trailer (A53317)
2015 Goose Neck...
2015 GENIE S-45 TELESCOPIC BOOM LIFT (A52709)
2015 GENIE S-45...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
