KUBOTA INTERCHANGEABLE LIGHT BAR
/ KUBOTA INTERCHANGEABLE LIGHT BAR #1
escavader
western maine
bx-23 ,
HI FOLKS,
I needed some lights,like every one else.because the days are getting shorter,and you have to quit so early.There is not much time to play....i mean WORK on the tractor after the regular day job. Some day i may want to get a different bota,and im gonna have to figure this out all over again.Kubota doesnt want you to weld or drill your rops,and i didnt want any liability from any future owner[you have to be paranoid these days],so with all this in mind heres what i come up with.
How about an interchangeable light bar,that clamps to the rops,with all the switchs and electrics inside.First i got some 4 inch muffler clamps and modified them[grinded] to set on the flat rops. Next a piece of pipe,the round clamps,will hold it better.I then welded the light brackets on the pipe.You can put these wherever you want,i chose two front facing,and one rear hoe light.I then drilled some wire holes just the right size for rubber grommets.I made holes for my two toggles,one for the fronts,and one for my hoe light.A little primer and paint,and start assemblin.
I used them last night ,for some hoe work,and fel work and its just like day time.!!!!!!!!!!!!!!!! /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif.I shut off the reg lights so not to over tax the electrical systems out put.......They are use less any way.
With this design ,i can put them on any rops,and dont have to figure out where to toggle,just one wire,to hook to a power supply.I forgot to mention i installed an in line fuse holder,even though the aux circuit is already fused.
Heres a pic of most every thing on the work bench,guess i forgot to show the clamps.......................
ALAN
Re: KUBOTA INTERCHANGEABLE LIGHT BAR
Heres a rear view on the tractor
ALAN
.....FRONT VIEW..NOTE THE SWITCHS
ALAN
Heres where i hooked in under the seat,didny use the ground-lights self grounding
hope this all gives someone ideas
ALAN
/ KUBOTA INTERCHANGEABLE LIGHT BAR #5
Hey that's pretty nice. I might have to copy your idea. Thanks for the post.
/ KUBOTA INTERCHANGEABLE LIGHT BAR #6
That's great. Thanks for the pics and post.
/ KUBOTA INTERCHANGEABLE LIGHT BAR #7
Looks great! I like it a lot better'n what I've got...
/ KUBOTA INTERCHANGEABLE LIGHT BAR #8
Yup the head lights arent much good. I was thinking along the same idea, looks good have to keep this in mind. :thumbsup:
/ KUBOTA INTERCHANGEABLE LIGHT BAR #9
You need to patent that and sell that. I'll be the first one to buy it. LOL That is a great design and thought about doing the same just never bought the stuff to do it.
Great Job :thumbsup:
This is a very old post of mine.I now have a cab on my 23 year round with lights on it.I did however keep the light bar,in case i ever get a second tractor thats open stationed.They always worked great
ALAN
2009 VOLVO VNM 300 6X4  T/A DAY CAB TRUCK TRACTOR (A59906)
2009 VOLVO VNM 300...
New/Unused Landhonor Gantry Crane (A65583)
New/Unused...
2018 LIEBHERR A900C LITRONIC WHEELED EXCAVATOR (A63276)
2018 LIEBHERR...
3pt Hitch Receiver  (A62679)
3pt Hitch Receiver...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
