kubota ignition key
   / kubota ignition key #1
locker
florence, al
kubota 3100
I lost my Kubota compact tractor key today and need toSTART it move my tractor what are my options.
   / kubota ignition key #2
You can hotwire it pretty easy if you have access behind the key (or can remove the keyswitch)
Easiest way it to just go to the dealer ASAP and get a new key.
   / kubota ignition key #3
   / kubota ignition key #4
If one of your neighbors has a Kubota, try his key until you get another one. It will probably start it. Just a thought.
   / kubota ignition key #5
Or....this is a long shot.. since the late model keys are all alike, perhaps someone here could scan their key, and post it as a pdf or jpg. with a ruler to scale it by, and you could saw and file one out of sheet steel. Like I said, a long shot, and a lot of work, but, it did come to mind as a possibility.
James K0UA
   / kubota ignition key #6
I went to the boy scout camp and forgot my key at home(2 hour drive). Another small key on my ring started the tractor and I left it run all day.
   / kubota ignition key #7
Where is your spare key? I got 2 keys with mine. :D
Ken
Wilrich Field Cultivator (A50515)
Wilrich Field...
2021 New Holland C327 Compact Track Loader (A52128)
2021 New Holland...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2009 Ford F-250 Pickup Truck, VIN # 1FTSX21Y49EA41686 (A48836)
2009 Ford F-250...
2017 Freightliner Cascadia 125 Single Axle Sleeper Cab Truck Tractor (A50323)
2017 Freightliner...
2017 JOHN DEERE 350G EXCAVATOR (A51242)
2017 JOHN DEERE...
