Kubota hydro oil filter drains all of the fluid
   / Kubota hydro oil filter drains all of the fluid #1
Steelphoenix
Masontown, Pa
L3710 Grand Kubota
I'm having trouble with my L370Grand losing oil from the HST vent. I mean it flows out in a steady stream. I pulled the filter off and all 10.5 gallons ran out. Is this normal?
   / Kubota hydro oil filter drains all of the fluid #2
If memory serves, removing the hydraulic suction filter will drain the majority of the sump. Removing the transmission filter will drain a quart or so max.
   / Kubota hydro oil filter drains all of the fluid #3
I'm guessing by the vent you mean up on top by the fill? Fluid shouldn't becoming out of there, was it over filled
If you don't want to drain all the fluid out, you can hook up a shop vac to the fill port, which causes enough suction so it won't run out the bottom ...
no, on top of the hst is a rubber u-shaped tube that curls downward. About 3 inches long and is clearly a vent.
   / Kubota hydro oil filter drains all of the fluid #5
This is the vent on mine, it is part of the fill cap, next to the dip stick ... Is that where the fluid is coming out?
Mine looks like that but it is on a separate bung by itself. This machine has a cab on it so the filler cap is in the rear above the 3 pt.
Thats exactly what happened. I was able to catch the majority of it and strained it to look for debris or metal, there was no metal and just a small amount of dirt in suspended in the fluid on the bottom of the bucket.
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A55218)
2021 John Deere...
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
UNUSED LANDHONOR LHR-DFP10 DSL FUEL TRANSFER PUMP (A54757)
UNUSED LANDHONOR...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51247)
(NEW) 2025 DOWN 2...
