Kubota Hydraulics
/ Kubota Hydraulics #1
lineberry
I have a L2600 series tractor with a front end loader. I am trying to hook up a post driver. I have t'd the hydraulic line into the block for my line to raise the driver and run the outlet hose on the driver outlet to go back into the cavity of the tractor. The problem is that the only thing that moves when I use the driver is the 3 point hitch. Do I need to buy a another device to run the driver separately? Any help would be appreciated.
/ Kubota Hydraulics #2
You cannot tee into a hydraulic pressure line. The fluid will always take the path of least resistance. Valves in your tractor's hydraulic system must all be connected in series with each other.
How have to buy an aux valve configured with power beyond. The number of spools on the valve will be determined by your needs (ie, how many functions do you want). The installation is no different than adding a valve for rear remotes. Do a search here on TBN for Rear Remotes. I have described the installation and plumbing precedures many, many times.
2715SSFL (A61567)
2715SSFL (A61567)
UNUSED WOLVERINE BUCKET (A64281)
UNUSED WOLVERINE...
2026 Stout TB-76 Tri-Blade Brush Cutter (A64047)
2026 Stout TB-76...
LOAD OUT AND SHIPPING (A65583)
LOAD OUT AND...
2009 Case CX240B Excavator (A64194)
2009 Case CX240B...
2018 Komatsu D61PX Crawler Tractor Dozer (A59228)
2018 Komatsu D61PX...
