Kubota Hydraulics Question
   / Kubota Hydraulics Question #1
mcd176
Wheeling, WV
Kubota M6800HD / Kubota B2150
I have a Kubota L4200 CUT, My question is this: Does my tractor have "OPEN" or "CLOSED" center hydraulics?
   / Kubota Hydraulics Question #3
Yep...Open Center.
   / Kubota Hydraulics Question #5
Thanks, I was looking into a double selector valve like the link below
https://www.surpluscenter.com/item.asp?item=9-5117&catname=hydraulic
OK, that is what is commonly called a "diverter" valve. Basically it has ONE input and TWO outputs. They are used to "divert" fluid from say the dump/curl cylinders to a grapple on your loader. The 9-5117A is a better one to get because it does not require constant power. Also, the 9-7852 is smaller and $10 cheaper.
Either of these valves won't care if your system is OC or CC, since they are used after the spool valve.
What are you trying to do?
KennyD,
I was looking into using it for my rear remote, I only have one and need two and this looks to be a cheaper option, I looked into the fasse valves and this appears to be the same valve body less the hook-ups, This is a link to what I am talking about: Fasse Hydraulic Valve Multipliers
I do like the valve you gave me the link to for my front end loader because I do plan on adding a grapple in the near future.
   / Kubota Hydraulics Question #7
The Fasse is a good peice, it should include everything you need-but at a higher cost. They only sell through dealers, so you will have to check with yours for pricing.
Scag STT61V 61in Zero Turn Mower (A51691)
Scag STT61V 61in...
2012 Dodge Grand Caravan Van (A51694)
2012 Dodge Grand...
CFG Industrial SAII100 (A50123)
CFG Industrial...
1999 LinkBelt HTC8650 50 Ton Crane Boom Truck (A53117)
1999 LinkBelt...
2014 Ford F-150 Pickup Truck (A51692)
2014 Ford F-150...
safety baskets (A53421)
safety baskets...
