Kubota Hydraulics not working after hose repair
   / Kubota Hydraulics not working after hose repair #1
Dano11
Kubota l3130
L3130. Replaced blown bucket hose. After repair pump whines and no hydraulic action. Tractor will move but no loader or rear lift. Checked for all hose connections and changed out both rubber suction hoses. It was suggested water got in hyd oil, causing a gel blocking filter. Pulled and checked ok. Not sure if there is a way to purge air out?
   / Kubota Hydraulics not working after hose repair #2
How many lines did you have to remove to do this repair? Which line blew? One of the lines to the lift - lower or bucket curl - dump?
   / Kubota Hydraulics not working after hose repair #3
Did you check the fluid level?
20702 (A51694)
20702 (A51694)
2001 Ford F150 (A50121)
2001 Ford F150...
2025 GIYI GY-BK56M 56in Excavator Boom Skid Steer Attachment (A53421)
2025 GIYI GY-BK56M...
2013 Great Dane 53ft T/A Reefer Trailer (A51694)
2013 Great Dane...
48" WIDE WOODEN W/ METAL RAILING (A54757)
48" WIDE WOODEN W/...
