kubota hydraulic problem
/ kubota hydraulic problem #1
mrgraphixx
I bought a used B7200 4WD and just purchased a used 1640 lader attachment for it.
It seems I have a B7200 with power steering and my dealer says they never made one.
Here is my problem:
Instead of a 2 port hydraulic block, I have one that has 4 ports. The upper two ports have threaded brass inserts with 1/4 inch holes drilled through them with a deep (1 inch) thread at the end of the brass piece. You can not thread a hydraulic line into those ports.
Under that are 2 more ports, threaded to accept a hydraulic line but I have connected to those two ports, tried it, reversed the connections and tried again but still have no hydrauic power. The 3 point hitch works fine, the power steering, which also comes from the bottom of this 4 point plug works fine.
I am at wits end. Has anyone ever seen this setup before ?
/ kubota hydraulic problem #2
Just how many forums you gonna post this on.
It appears in the Kubota forum, Hydraulic forum, and here in the customization forum.
I know you think more copies of the same message will get you more coverage.. however it creates duplicate posts.
A single post will garner just as much good info and responses as multiple posts.
Soundguy
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
UNUSED WOLVERINE RCR-12-84W-84" HYD ROCK RAKE (A64281)
UNUSED WOLVERINE...
iDrive TDS-2010H...
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
2025 X-Pro Victor Mini Dirt Bike (A61574)
2025 X-Pro Victor...
378909 (A61166)
378909 (A61166)
