kubota hydraulic problem
   / kubota hydraulic problem #1
mrgraphixx
I bought a used B7200 4WD and just purchased a used 1640 lader attachment for it.
It seems I have a B7200 with power steering and my dealer says they never made one.
Here is my problem:
Instead of a 2 port hydraulic block, I have one that has 4 ports. The upper two ports have threaded brass inserts with 1/4 inch holes drilled through them with a deep (1 inch) thread at the end of the brass piece. You can not thread a hydraulic line into those ports.
Under that are 2 more ports, threaded to accept a hydraulic line but I have connected to those two ports, tried it, reversed the connections and tried again but still have no hydrauic power. The 3 point hitch works fine, the power steering, which also comes from the bottom of this 4 point plug works fine.
I am at wits end. Has anyone ever seen this setup before ?
   / kubota hydraulic problem #2
Just how many forums you gonna post this on.
It appears in the Kubota forum, Hydraulic forum, and here in the customization forum.
I know you think more copies of the same message will get you more coverage.. however it creates duplicate posts.
A single post will garner just as much good info and responses as multiple posts.
Soundguy
2017 Nissan Rogue SUV (A50324)
2017 Nissan Rogue...
John Deere 4640 Tractor (A50514)
John Deere 4640...
Kubota 2 Cyl Engine (A50774)
Kubota 2 Cyl...
7' Snow Blade (A50515)
Wacker Neuson ST31 (A50120)
Wacker Neuson ST31...
2022 Ford F-550 Cab and Chassis Truck (A50323)
2022 Ford F-550...
