kubota hoe on a TC
   / kubota hoe on a TC #1
schmism
Super Member
Peoria IL
New holland TC(33)
So i think ive got a line on the hoe that comes off the BX size machines. But looking at it it seems to clamp? on to the rear of a BX somehow not useing the 3pt.
Im fairly shure i can get the hoe for slightly less than an entry level cheepy (taylor way etc).
the question is, is there any reason i cant fab up some sort of frame work on the back of my TC to mount the thing? I do have a power beyond...
discuss:
   / kubota hoe on a TC #2
Not worth the effort. The hoe from a BX will be about 1/2 the stength of something that would fit on your TC33 - NH's 757/758 Woods BH80X etc.
BX is a 1,200# machine (base) , your TC is about 2,500 w/o loader.
If looking used - try to find a woods, bradco, bush hog, rhino (NH OEM if I rember right) etc - that you can get a subframe for to fit your TC33.
   / kubota hoe on a TC #3
I should also note that said subframes seem to be incompatible with your MMM mounts. I know for certain on the TC18 that the New Holland & Woods units would require that I removed the MMM brackets to mount the hoe.
   / kubota hoe on a TC #4
schmism
The Bx23 mounts by setting on a bar at the bottom on the frame with the out riggers, then you swing it up with boom to latch it on 2 points on top back of frame and insert 2 hair pins to lock latch.
No real sub frame like some others.
You turn the seat around on the tractor to use controls.
it takes me about 3 minuets to take mine off and and about 10 to get it on
(getting it ligned up side to side is some times hard).
tommu56
yes ive gathered this. which is why i was shooting for a smaller 3pt style hoe with custom subframe to mount someplace under the tractor (with the MMM deck off but brackets in place)
My digging needs are limited so i think a small 7' hoe would be fine.
   / kubota hoe on a TC #6
I believe that woods makes a subframe that allows MMM brackets to remain.
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
7ft Dozer Blade Skid Steer Attachment (A51573)
7ft Dozer Blade...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
2012 CATERPILLAR 308E CR EXCAVATOR (A51246)
2012 CATERPILLAR...
