kubota heavy black smoke
   / kubota heavy black smoke #1
krazy101
Catlett,Va.
jacobsen-AR522
I have a 2008 kubota v2003 turbo charged 4cyl motor. Heavy black smoke from exhaust after brief warm up. It appears to be pushing/sucking oil thru the turbo charger and into the air intake manifold.I installed a new turbo charger,cleaned and inspected oil tubes to turbo charger,cleaned all aspects of the fuel system and air intake system to ensure there were no blockages. Ran a compression test all 4 cyls at 400lbs each. So if anyone has any leads please help me out. Thanks.
   / kubota heavy black smoke #2
How long has it ran since you cleaned the lines and replaced the turbo? Could be residual oil in the intake manifold or valve stem guides could be leaking.
   / kubota heavy black smoke #3
Black smoke is typically a lack of air or too much fuel (plugged air filter/faulty injector) excess oil usually produces blueish smoke.
ran about 8 to 10 hrs after new turbo.no black smoke at first, took about 2 hrs of running before started smoking under a load.oil was in air intake again at that point.
brain55, I kinda feel like it is a faulty injector/s but why is it pushing any excess fuel/oil mix back thru the turbo charger?? Also oil consumption increased when this started happening. As you all can see i am NOT a great diesel mechanic.
   / kubota heavy black smoke #6
Is there to much motor oil in it.......
Is there to much motor oil in it....... Nope
   / kubota heavy black smoke #8
The (lack of air/overfueling) could also be due to the turbo being bad (even though it seems unlikely with that few of hours) it could explain the other symptoms.
   / kubota heavy black smoke #9
Take the down pipe off of the turbo (the one that goes to the muffler) and see if there is a lot of oil in there. If there is the turbo was not put back together correct and or the seal is bad.
If no oil than it's a fuel / air issue.
   / kubota heavy black smoke #10
Most likely you've blown an oil seal in the turbo if you have engine lube oil leaking in the inlet or the exhaust. With out direct knowledge of your specific turbo design, that's about all I can say at this point. If it were leaking out the turbine exhaust I believe it would be bluish smoke. If it's leaking into the compressor than it's entering the combustion chamber and essentially over fueling the engine. In this scenario, the blue lube oil smoke may be masked by partially burned fuel which leads to black smoke. Is the coolant temperature staying where it is normally? Is it staying out of the red zone ?
Pictures may help but you definitely want to get this sorted out before operating it any more.
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2013 HYUNDAI VC2530152 53FT DRY VAN TRAILER (A53426)
2013 HYUNDAI...
2025 Forklift Safety Man Basket (A51691)
2025 Forklift...
UNUSED WOLVERINE BC-13-72W-72" HYD BRUSH CUTTER (A51248)
UNUSED WOLVERINE...
2007 CATERPILLAR 330DL EXCAVATOR (A51246)
2007 CATERPILLAR...
2025 CFG Industrial QK18R (A50123)
2025 CFG...
