Kubota GR2100 backing up question
   / Kubota GR2100 backing up question #1
eaf
Bronze Member
Hartselle, Alabama
Kubota L3130 GST 4x4, BX25D-1, RTV 1100, Craftsman FS5500
I have a GR2100 with 8 hrs on the clock now and ready to hook the Cyclone Rake up. I would like to know if other GR owners have experienced the lack of power to back up any of the steep slopes in their yard? There are a few places in my front yard that are fairly steep and without my CR hooked up it really struggles to back up. I was wondering if with the Cyclone Rake hooked up, loaded with debris would be able to back up if needed without blowing the transmission out on to the ground. I haven’t hooked the CR up yet, I have to modify the hitch mechanism to fit to the back end of the mower. Something I might be able to do in the next week, if I can bring myself to welding on the new toy. Anyhow any feed back on backing up a hill or suggestions would be appreciated.
   / Kubota GR2100 backing up question #2
Re: Kubota GR2100 backing up question
You may have a jam nut loose or just out of adjustment. Mine was loose when delivered. I will post a picture of the nuts...they are right below the pedal. The top bolt/nut/jamnut is for forward...the bottom is for reverse. FWIW, when properly adjusted my GR will climb anything backward that it will forward...
Slam
Thanks Slam, I’ll check it out tomorrow to see if the nuts are loose or out of adjustment. I guess from the looks of your set up, I’ll see if mine close to yours. One thing I just remembered (I'm over 50) is that I have not been running at full throttle, it being new I had been running it at about 80%. That may be the problem the hydro pump not building up enough pressure to drive it up a steep slope in reverse. I should have CR hookup completed by the end of the week and try it out on the yard.
Thanks again for the advice.
   / Kubota GR2100 backing up question #4
No problem...be sure and let us know how it goes... /forums/images/graemlins/grin.gif
Slam
Well I finally got the CR hooked up to my GR2100. see the following attachments. The question I had earlier about having enough power to backup my steep hill here at the house. No problem with the CR attached and full of mulch. I was following the break in instructions not to run full throttle, at full throttle it backs up the steepest hill with no problem.
Right side
Rear bracket attach point
Collector Bracket Rear
Collector Bracket Front
Collector Bracket Top
