kubota gone crazy
/ kubota gone crazy #1
john golubinski
Hastings florida
Ditch witch c99,oliver oc4, ford 9 n,john Deere 314 ,bachtold dr field and brush mower
my diesel is acting like the timing is off when you put your hand over the exhaust it pulls it in and when you put your hand over the intake is blows out,wont start need help with what to look for
/ kubota gone crazy #2
Please start by telling us what model it is and what it was doing before it quit running. Also knowing where you are from will help too, if we need to refer you to somebody to help you.
Brian
/ kubota gone crazy #3
Welcome to TBN John. Brian is right more info would be helpful. With info given we can say for sure that its not right. :D
/ kubota gone crazy #5
now you gave us all a good stumper to think about.but ive never heard of a tractor motor running backwards.but i do know the detroit motors will run backwards if over lugged or bumped way to hard in reverse.
/ kubota gone crazy #6
I have seen a Kubota run backwards, it was being abused with a logging winch. It was shut off , restarted and was ok.
/ kubota gone crazy #7
Early B9200's had a problem with soft timing gears. I don't remember any problems with the G5200's. I would start by pulling off the valve cover and rotating the engine by hand to make sure the valves are opening and closing. Next, I would pull the site plug out of the side of the bellhousing and see if on #1 TDC both valves are closed if on the compression stroke or both valves are slightly open on the exhaust stroke. If there is a problem in either area I would suspect that the timing gears are damaged. The engine should rotate clockwise looking at the front of the engine.
Brian
/ kubota gone crazy #8
Does sound like it's running backwards, air filter will not last long, may even catch fire, beware!
/ kubota gone crazy #9
I used to work for a company that run 671 Detroits in all their trucks and quite often one would stall allllllll-most then at the last second re-start running backwards it is unmisteakable sounding would be running but no power when put in gear.Hve to shut it off and try again.:confused2:
/ kubota gone crazy #10
while I've heard of certain diesels running backwards ( wow.. no oil pressure!! ).. I wonder if perhaps he doesn't have some stuck valves. or problem in valve timing instead?
soundguy
/ kubota gone crazy #11
Many moons ago when I was a kid me and a a buddy pull started a little Kubota with a dead battery, it started but suddenly had 1 forward gear and 4 reverse gears. Dumb kids!! As far as I remember, it it was fine after (but the battery was still dead):laughing::laughing:
I think it was an old L175.
/ kubota gone crazy #13
Sounds like it was running backwards. I have seen a John Deere 730
2 cylinder diesel run backwards. It was running on a dyno when it was lugged down and died. When he restarted it, it ran backwards. He was trying hard to kill it and did get it done. They don't last long with the oil pump running backwards. If you have a clear precleaner and oil bath breather it is real evident as you will fill the precleaner with oil. I was also on a Case 930 diesel and I was being pulled started and it fired backwards. It filled the precleaner with oil as well. It took a split second to to figure out what was going on. First time I had experienced it. Detriots seem to do it more often than any other engine. Being a 2 cycle diesel I would think contributes to that.
/ kubota gone crazy #14
sniff sniff
one post
sniff sniff
crazy problem
sniff sniff
Is that the sickly sweet scent of a troll?:laughing:
17601CFL (A59228)
17601CFL (A59228)
ROADTEC RX700 MILLING MACHINE (A64279)
ROADTEC RX700...
John Deere 8400 Tractor w/ Duals (A64047)
John Deere 8400...
2021 CAM p4EC16W102 16ft. 7000lb Utility Trailer (A64047)
2021 CAM...
130 BBL VAC TRAILER (A63569)
130 BBL VAC...
INTERNATIONAL 720 - 6 BOTTOM PLOW (A63291)
INTERNATIONAL 720...
