Kubota gears stuck
   / Kubota gears stuck #1
bluiblonde4evr
RTV KUBOTA 900 SERIES,CASE,AND JOHN DEER
hello everyone, I"m new here so be patient with me:).
I have a Kubota, that is stuck in Nuetral , can anyone give me some advice on what to do..
have a great day......
   / Kubota gears stuck #2
It would help a lot if you could tell us the model and what type of transmission it has.
MarkV
Hi, Sorry for the lack of info. just be patient with me until I get the hang of things on this site. thanks/
well I'm not sure of the transmission but it"s a rtv 900 kubota and the gear is stuck in medium not nuetral like I thought . and its in 2wd also, there is a pull knob to disengage gears but This does not workl I guess Unless we are doing something wrong..
:confused:
   / Kubota gears stuck #4
Can you move the shifter at all?
no the lever will move toward nuetral but stays n gear all others you would have to force and stays in m too,
   / Kubota gears stuck #6
you may have it fixed by now
I assume you have verified the physical shift links to transmission are good ?
   / Kubota gears stuck #7
I have had this happen on my rtv once or twice.As near as I can figure it happens when you have a load on transmission and then try to quickly change gears to back up or the likes when stuck or something that would put presure on drive system.I have found that instead of being in a hurry alow time for presure to equalize it will come out of gear easily after 10 seconds or so. I have always gotten back to working just by moving the lever around with presure off or pull release cable on dash. hope this helps
   / Kubota gears stuck #8
The shifting can be quirky and takes some getting used to. Have you read the Owner's Manual?
Steve
   / Kubota gears stuck #9
Move forward a bit or in reverse this while aline the gears my 4 wheeler and the tractor do this
   / Kubota gears stuck #10
I have a Kubota l-3010 that does the same thing. It scared men good the first time thought it was serious . Come to find that it occurs when the engine is shutoff in gear and on a hill placing a load on the transmission. Standing behind the tractor look under the cowling and follow the shift lever down to the slots that the shift lever slips into to allow shifting. You will find one is misaligned with the lever move it by hand to allow the shifting to occur. Watch your fingers! This is my problem hope it is yours also............good luck .Jesse
CFG Industrial MX12RX (A56469)
CFG Industrial...
JOHN DEERE XUV590M LOT NUMBER 27 (A53084)
JOHN DEERE XUV590M...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A55315)
2017 Cadillac...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A53843)
2011 MAGNUM...
2017 ford f-250 (A56858)
2017 ford f-250...
2010 LAREDO 5TH WHEEL (A55745)
2010 LAREDO 5TH...
