Kubota G5200 Aux Hydraulics??
   / Kubota G5200 Aux Hydraulics?? #1
w4bss
Hodges, SC
Kubota HST G5200
I have a Kubota G5200 HST, and im wanting to know is it possible to add some type of Aux Hydraulic control so I could use a Hydraulic attachment? If so were would I start at? I have a small loader that im wanting to put on this mower as well.
Thanks for the help!!
This is the Kubota thats in my Sig. Im just trying to get a idea were I need to start at. Does the HST act as a pump, does it have some type of connection?
   / Kubota G5200 Aux Hydraulics?? #3
You will most likely need to add a belt driven pump from the engine and add a separate reservoir. The hydrostatic transmission is a pump per say...but you can not really use it to feed another system.
Ok thanks kennyd. I was thinking I would have to add another pump but wasn't sure about it. Guess I will go on a hunt for a pump now.
   / Kubota G5200 Aux Hydraulics?? #5
Does your tractor not have a hyd pump for the 3pt.
If you need an aux pump, the 14 HP engine can support a 7 GPM pump, at 3000 psi, at 2500 rpm. The displacement will be .6 cu in.
This would be sitting still like using a BH. If you are driving the tractor, that will take some of the HP away from the hyd pump. This pump could also power your loader.
My Power-Trac, uses a belt driven hyd pump for the steering and loader circuit. It only pumps about 3 GPM. Something like below should work for your situation.
This hyd pump will pump 8 GPM.
Gear Pumps 250-061 Detailed Information
Thanks J_J for the reply & info on the pump. No my G5200 did not come with a 3pt, and I really wish it did. The deck is also manual lift. The tranny is a hydro but im sure it isn't capable of running any attachments. I sure wish my Dad had bought the Hydro lift & 3pt for this tractor since it was a option 20 years ago. But I have metal & a Miller welder, im sure I can rig something up. I will be looking into that pump you recommended.
Thanks again for your help & info!
Brandon
2017 John Deere 30G Mini Excavator (A50322)
2017 John Deere...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2016 Ford F-150...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
John Deere 4000 Tractor (RUNS) (A50774)
John Deere 4000...
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
JMR 72" Root Grapple (A50121)
JMR 72" Root...
