Kubota G5200 Aux Hydraulics??
   / Kubota G5200 Aux Hydraulics?? #1
w4bss
Hodges, SC
Kubota HST G5200
I have a Kubota G5200 HST, and im wanting to know is it possible to add some type of Aux Hydraulic control so I could use a Hydraulic attachment? If so were would I start at? I have a small loader that im wanting to put on this mower as well.
Thanks for the help!!
This is the Kubota thats in my Sig. Im just trying to get a idea were I need to start at. Does the HST act as a pump, does it have some type of connection?
   / Kubota G5200 Aux Hydraulics?? #3
You will most likely need to add a belt driven pump from the engine and add a separate reservoir. The hydrostatic transmission is a pump per say...but you can not really use it to feed another system.
Ok thanks kennyd. I was thinking I would have to add another pump but wasn't sure about it. Guess I will go on a hunt for a pump now.
   / Kubota G5200 Aux Hydraulics?? #5
Does your tractor not have a hyd pump for the 3pt.
If you need an aux pump, the 14 HP engine can support a 7 GPM pump, at 3000 psi, at 2500 rpm. The displacement will be .6 cu in.
This would be sitting still like using a BH. If you are driving the tractor, that will take some of the HP away from the hyd pump. This pump could also power your loader.
My Power-Trac, uses a belt driven hyd pump for the steering and loader circuit. It only pumps about 3 GPM. Something like below should work for your situation.
This hyd pump will pump 8 GPM.
Gear Pumps 250-061 Detailed Information
Thanks J_J for the reply & info on the pump. No my G5200 did not come with a 3pt, and I really wish it did. The deck is also manual lift. The tranny is a hydro but im sure it isn't capable of running any attachments. I sure wish my Dad had bought the Hydro lift & 3pt for this tractor since it was a option 20 years ago. But I have metal & a Miller welder, im sure I can rig something up. I will be looking into that pump you recommended.
Thanks again for your help & info!
Brandon
CATALOG IS A GUIDE ONLY!! (A50774)
CATALOG IS A GUIDE...
2021 Ford F-250 4x4 Ext. Cab Pickup Truck (A49461)
2021 Ford F-250...
10FT. S/A Utility Trailer (A49461)
10FT. S/A Utility...
2023 GTC 39 END DUMP TRAILER (A50854)
2023 GTC 39 END...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2018 John Deere 470G Hydraulic Excavator (A50322)
2018 John Deere...
