Oil & Fuel kubota fz2100 diesel lawn mower
   / kubota fz2100 diesel lawn mower #1
bigE4evr
Houston,Texas
Yanmar YM187
Looking for info on a Kubota FZ2100? diesel front end lawn mower. Have a friend thinking about buying one runs good don't know how many hrs. Does anybody own one that could come up with some info. Thanks
   / kubota fz2100 diesel lawn mower #2
Are you sure about the model number? Anyway, I have a F2400 and would be glad to share any info you want.
Thanks for the response Howard, not real sure of model # but it looks just like yours except the steering wheels are closer together.Any info on where to get a owner/operators manual would be great. Thanks again.
   / kubota fz2100 diesel lawn mower #5
I don't know what I was thinking of. The FZ2100 is the ZTR version of the F2100. The F2100 and F2400 are the same except for the engine - 21 hp and 24 hp respectively. I would not recommend the 2wd version unless you have very flat ground with no sidehills or ditches to mow. Also, I don't know if the FZ comes in 4wd - it might but I don't think I have ever seen one. I don't know where you might find an owner's manual except through a dealer or by chance on e-bay. If there is anything I can help you with let me know.
Thanks, Howard the version my friend is looking at is a 4wd model.Turns on a dime, will try a dealer for a manual. By the way what is a ZTR version?
   / kubota fz2100 diesel lawn mower #7
ZTR means zero turn radius. They trun even more sharply than ones like mine - which turns sharp enough for me, especially with individual wheel brakes.
   / kubota fz2100 diesel lawn mower #8
I have a FZ 2100, also have the owners manual, I can answer any questions you have. F-Front mower, Z- Zero turn. It is 4WD
   / kubota fz2100 diesel lawn mower #9
tRY GOOGLE For Manuals, E-Bay also.
   / kubota fz2100 diesel lawn mower #10
On a ZTR, the mowing deck is suspended from the frame of the machine and sits beneath the operator. The wheels that are in front of the mowing deck support the weight of the entire machine. Unlike a tractor, the engine is behind the operator.
An F mower is very much like a compact tractor with a rear finish mower on the 3 point hitch, but with the seat and steering wheel turned around facing the rear, and the discharge facing the side or the tractor. The wheels out in front of the mowing deck are anti-scalp wheels; they do not support the weight of the tractor. The front of the tractor is now the rear, and the rear is the front with the mower out in front of the operator.
An F series can turn more sharply than a small tractor, but a ZTR can do a 180 and leave no grass at all uncut. In tall grass, a ZTR can leave windrowing (the front weight bearing wheels can mash grass down flat before the mower gets to that point, preventing it from being cut-it may or may not pop back up later). On an F mower, it is possible to lift the deck (which is basically cantilevered out in front of the rest of the machine), allowing every blade of grass to be cut by a mower blade before a tire ever touches it. The lift mechanism is far more limited than a 3ph, however. Quick attach allows the mowing deck to be replaced by a number of other implements like sweepers, front blades, snowblowers, etc.
A ZTR is steered with twin joy sticks. Power is applied to the rear wheels independently. If you want to turn left, you push the right joy stick more than the left. This causes the right rear wheel to turn faster than the left and the greater push on the right side makes the unit turn left. You can even push the right lever forward and pull the left lever back, making one drive wheel turn forward and the other back. This causes the machine to pivot in place. This design is what allows the turn radius of zero.
The F series, being in essence a regular tractor driven in reverse, is steered by its rear wheels like a fork lift. As stated above, steering is with a steering wheel. This rear steering gives it a better turn radius than a regular tractor, but less than the ZTR.
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2014 MACK GU713 WATER TRUCK (A51247)
2014 MACK GU713...
2016 FREIGHTLINER CASCADIA DAYCAB (A53843)
2016 FREIGHTLINER...
20711 (A50323)
20711 (A50323)
2025 Star EV Capella 2+2 Electric Cart (A51694)
2025 Star EV...
