Kubota Front Propeller Shaft Knocking
   / Kubota Front Propeller Shaft Knocking #1
jzykan
Kubota 900 RTV
Good Day. First post here. I just bought a 2012 Kubota 900 RTV. It had a bad knock in the front end when driving at all speeds. We took off the front propeller shaft and the female splines on the front differential side was worn. Sent it to a machine shop and they resplined it and made sure the shaft was straight. We inspected the CV joints and repacked them and reinstalled the propeller shaft onto the machine. It started out no knock but then it developed same knock from around 7 mph to 15 mph then stops and runs smooth.1mph to 7 mph is smooth also. Any help would be greatly appreciated. Thanks.
   / Kubota Front Propeller Shaft Knocking #2
Put it up on blocks and run it to see where it is coming from exactly. You were very near the problem if it changed!!
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A56857)
2017 Kawasaki Mule...
2016 INTERNATIONAL 4300 SBA FLAT TOP ROAD TRACTOR (A58375)
2016 INTERNATIONAL...
2014 Kawasaki Mule 600 Utility Dump Cart (A55973)
2014 Kawasaki Mule...
TCM FD30T6T Forklift (A55973)
TCM FD30T6T...
2017 Ford F-150 Pickup Truck (A54814)
2017 Ford F-150...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
