Kubota Front Propeller Shaft Knocking
   / Kubota Front Propeller Shaft Knocking #1
jzykan
Kubota 900 RTV
Good Day. First post here. I just bought a 2012 Kubota 900 RTV. It had a bad knock in the front end when driving at all speeds. We took off the front propeller shaft and the female splines on the front differential side was worn. Sent it to a machine shop and they resplined it and made sure the shaft was straight. We inspected the CV joints and repacked them and reinstalled the propeller shaft onto the machine. It started out no knock but then it developed same knock from around 7 mph to 15 mph then stops and runs smooth.1mph to 7 mph is smooth also. Any help would be greatly appreciated. Thanks.
   / Kubota Front Propeller Shaft Knocking #2
Put it up on blocks and run it to see where it is coming from exactly. You were very near the problem if it changed!!
1998 INTERNATIONAL 9400 (A52472)
1998 INTERNATIONAL...
Ford Tractor (A50120)
2022 CASE 580 SUPER N BACKHOE (A51246)
2022 CASE 580...
2012 JACK COUNTY 130BBL VACUUM TRAILER (A52472)
2012 JACK COUNTY...
2014 FORD F250 XL SUPER DUTY CREW CAB TRUCK (A51406)
2014 FORD F250 XL...
2001 John Deere M665 (A50120)
2001 John Deere...
