Kubota Front mountd blade
/ Kubota Front mountd blade #1
L3130
NH
Kubota L3130
Can someone give a price on what a front blade costs for the L3130. How hard is it to install? I have a quick attach already.
/ Kubota Front mountd blade #2
Since you mention that you already have a QA. I assume you are referring to a FEL mounted blade. Curtis makes a skid steer adapter for their (part # 1FELB1B) blades that requires some welding. You would also need to add a hydraulic valve to run power angle if you want that option.
Quick attach for loader bucket only. Don't want to weld anything if I don't have to.
/ Kubota Front mountd blade #4
As I understand it from the Curtis brochure, their FEL mounted snow blade requires an optional and extra cost skid steer style quick attach bracket that must be welded to their plow's push frame.
Using this setup on a Kubota assumes that you have purchased the skid steer style QA option on your FEL.
Here's a picture of their blade with the optional skid steer QA bracket in place (number 7).
Here's the Curtis FEL Blades website. It includes list prices for the blade and adapters (no shipping, no adapter installation cost).
Hope this helps.
Thanks alot. Looks good. I have a Mig welder, But I was under the impression that I had to be welded to the kubota QA bracket?
/ Kubota Front mountd blade #6
I have a Horst QA that is what Kubota's QA is, so I bought an extra bracket and welded up a frame and mounted a 71/2' Fisher plow to it. I use the rear remotes for the power angle feature. Send me you e-mail and I will send some pic's or do a search cause I think there are some here under projects.
2006 Dodge Ram 1500 Pickup Truck (A61568)
2006 Dodge Ram...
TerraGator L3020G4 (A64119)
TerraGator L3020G4...
2008 Case IH 2152 Combine Header (A63688)
2008 Case IH 2152...
2011 Ford F750 Dump Truck (A62613)
2011 Ford F750...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
2008 Mercury Grand Marquis LS (A62613)
2008 Mercury Grand...
