Kubota front gearbox/spindle leaking
   / Kubota front gearbox/spindle leaking #1
joea99
Platinum Member
Marbletown NY
Kubota B21, JD 240GT
Kubota B21. Right front wheel and tire has gear oil on it. Dripped down from somewhere on the gearbox, I guess. Noticed it while changing hydraulic oil and filters. Was getting dark so did not try to isolate it.
Any one know if the seals can be replaced without completely tearing down the assembly? Looks like there are two seals, on inner and one outer. So, I guess it is a tear down.
   / Kubota front gearbox/spindle leaking #2
I abused my 4wd tractor. I paid the price: First sign was what you see. Just figured a leaking seal on a 10 year old tractor. Then I noticed the wheel hub casting started separating from the axle gear casting, barely noticeable at first and over a few hours expanded. When it got to one quarter inch I figured I had a problem.
I did, the abuse broke one of the balls in the main wheel support bearing best I could tell. This metal ball remnants got into several things and started eating up parts. Result was $600 worth of parts only, I did the work, for both sides. The other side wasn't showing but I decided to open it up and check it and glad I did as it too was damaged but I caught it before the damage was as bad as the one that caught my attention.
So, sir, my advice to you is to check things out. May be time to drain your oil anyway. On mine, pop the wheel and the casting with the wheel studs has about 12ish bolts in it. Removing them allows you to remove the wheel/gear drive assembly. All my problems were in that assembly which was a rather simple bench repair operation. Had never been into a front end and had nothing but the parts diagram but that was enough to identify what failed and get the right parts.
The owners manual said to use the same fluid in the front axle you used in the main sump. The knowledgeable guy at the Branson parts warehouse in Plainview, TX. said that i should be using 85w-140 in that front end, not what's recommended in the owners manual.....printed some 10 years ago when I bought the tractor....apparently in that time things have changed. The 2016 2400 I bought last year is only 24 hp, not 65 but it specs 90w for the front gear box. They had all the parts I needed to make my repairs in stock and I had them in about 3 days.
Thanks for the info. I was doing fluid change anyway and was going to do the front as well. No time like the present. I have enough "Super UDT2" name brand fluid, but, the do spec 80 /90 front as well. What's leaking looks like regular gear oil.
   / Kubota front gearbox/spindle leaking #5
Always locate and check vents before assuming seals are bad. Doesn't matter what brand or model tractor you have. When oil gets hot and expands it has to be able to vent the hot air above it or it will find another means. Usually by pushing the oil out of an otherwise good seal.
2018 CATERPILLAR 320GC EXCAVATOR (A51242)
2018 CATERPILLAR...
3000 Gallon Black Poly Water Tank (A49461)
3000 Gallon Black...
2012 Ram 1500 4x4 Crew Cab Pickup Truck (A49461)
2012 Ram 1500 4x4...
Adams 5 ton Fertilizer Buggy / Wagon (A51039)
Adams 5 ton...
2012 FREIGHTLINER CASCADIA (A50854)
2012 FREIGHTLINER...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
