Kubota Front Axle Vent
   / Kubota Front Axle Vent #13
Some are not vented. Keeps a positive pressure and does not allow water In.
   / Kubota Front Axle Vent #14
If you do add a vent, put it in the center of the axle, not on one end. Unless you operate on flat land only. My Branson has a factory vent on one end and it leaks if I park the tractor on a side slope with that side on the downhill. The dealer sent me an extension which helps some but does not fix it.
   / Kubota Front Axle Vent #15
I went back out to the barn this morning and took the side panels off the L5740 to get a better look. I spent a good bit of time looking things over and I couldn't find any vent lines connected to the axle. It's strange that Kubota feels the need to vent some models but not others. I dont spend much time doing deep water crossings so I would imagine the benefit of having the axle vented would outweigh the possibility of water intrusion. I still plan on tapping the fill plug, adding a 90 degree barb and running a vent line along the top of the axle to a termination point up under the hood. The top of the axle is pretty well protected. Any gear oil that happened to leak into the line on a slope would be able to drain back into the axle.
I have looked all over my L45 axles and cannot find a hose coming off of it. I will probably add a vent as well
   / Kubota Front Axle Vent #17
My B does not have a front axle vent. A Kubota rep at a dealer show I attended told me it is like this and is supposed to have some pressure to keep contaminates out.
We only got into the conversation because I was asking him about all the forum people that think this will cause an oil leak past the seal and they go and make some kind of homemade vent.
   / Kubota Front Axle Vent #18
They're vented. My M7040 has a vent that exits behind the battery in front of the radiator. I overfilled my front axle and it blew oil all over the front battery tray and radiator.
NEW Woods 6ft Finish Mower (A56436)
NEW Woods 6ft...
2026 Anvil T/A Enclosed Trailer (A56859)
2026 Anvil T/A...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2015 Ford Taurus AWD Sedan (A54815)
2015 Ford Taurus...
