Kubota front axle, hydraulic fluid or gear oil?
   / Kubota front axle, hydraulic fluid or gear oil? #21
From the Kubota manual...
Front axle case 4.5 L, 4.8 U.S.qts., 3.9 Imp.qts. KUBOTA UDT or SUPER UDT fluid* or SAE80, 90 gear oil
Would you put in hydraulic fluid (UDT or Super UDT) or some 80W-90 gear oil? Going to change out the front axle fluid & thinking I'll just pick up some 80w-90 tomorow, but wondering if anybody had any opinions as they are both recommended by Kubota.
I hes gear oil in both of my Kubota's simply because gear oil better absorbs the shocks of gear movement when in 4wd when I'm moving and loading round bales in the field but UDT or SUDT works as well plus gear oil provides better boundary lubrication to the outboard bearings, something I've had fail in the past and they are a PITA to replace.
   / Kubota front axle, hydraulic fluid or gear oil? #22
Their opinion:
   / Kubota front axle, hydraulic fluid or gear oil? #23
Where did you read this?
Can you post a link to it , please?
The particular elastomer composition would have to be discussed, to start.
I’d love to see an actual technical study that compared a gearbox lubricated with good gear oil against a gearbox lubricated with UTTO, where they found the seals leak sooner with gear oil, than with with UTTO.
wish I could.
IIRC correctly, it was one of the big makers. J-D or the like comparing their own fluids.
I gave a look, but I'm already on the boat, so ....
   / Kubota front axle, hydraulic fluid or gear oil? #24
I get a kick out of Messics ads. Always pandering to buy their products...lol Apparent they also recommend 90 weight gear oil, what I use in my Kubota's
   / Kubota front axle, hydraulic fluid or gear oil? #25
The video has the guy holding 2 different Tutela brand oils, which can be bought anywhere, including Amazon.
Not sure what you saw.
   / Kubota front axle, hydraulic fluid or gear oil? #26
Should we get into the SUTO?
"or whatever the achronym"
It's even good for ENGINE oil!
One Fluid to rule them all!
   / Kubota front axle, hydraulic fluid or gear oil? #28
Valvoline conventional 75-90 gear oil.
   / Kubota front axle, hydraulic fluid or gear oil? #29
I get it that Kubota recommends either UDT or gear oil, but can I top off the fluid with either one? Not sure what's in the tractor now (from the factory).
Same here. Have a little extra UDT2 so going to use it to top it off.
2021 Allmand Maxi-Lite II 20kW Towable Light Tower (A52377)
2021 Allmand...
2018 GENIE GTH-844 TELESCOPIC FORKLIFT (A52706)
2018 GENIE GTH-844...
2019 Chevrolet Cruze Sedan (A53424)
2019 Chevrolet...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2007 DRAGON 150...
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
