Kubota Finish Mower Repair
   / Kubota Finish Mower Repair #1
yellowyj
Alabama
Kubota L3010 HST
How hard is it to change the spindles and bearings on a 60" Kubota Rear Finish Mower?
What should I expect the parts to cost?
What is the approximate value of a used 60" Kubota Finish Mower with bad spindles and bearings?
Any help is greatly appreciated.
   / Kubota Finish Mower Repair #2
Do you know the model number of your mower?
Don't know for sure, but I think it is a RFM-60. I would have to check it out this weekend to know for sure.
   / Kubota Finish Mower Repair #4
My guess at the cost of the spindle assemblies will be about $100 each. When I replaced them on my Woods mower the cost of buying whole new assembles wasn't much different than buying all the parts to rebuild them.
Good Luck,
Kevin
   / Kubota Finish Mower Repair #5
Yellowyj when I replaced a single spindle assembly this past summer I believe the cost was 80 bucks per assembled spindle. Its a piece of cake to do the labor yourself. Replacing the worn spindles, sharpening the blades, and replacing the belt(s) will put you back in "like new" condition for mowing.
   / Kubota Finish Mower Repair #6
Spindle Assembly is about $140.00
Spindle Shaft $26.00
Bearings $9.00 each
Upper & Lower Seals $7.00 for both
   / Kubota Finish Mower Repair #7
I'd be looking at all three spindles as well as the idlers and belt. /forums/images/graemlins/ooo.gif Take the belt off and spin all spindles and idlers that the belt rides on and feel for irregularities in sound and touch as you slowly spin them. /forums/images/graemlins/confused.gif You might find one that isn't in much better shape and as long as you are there fix those also. You should check the deck too for weak spots. /forums/images/graemlins/blush.gif Some times the continual friction will wear thru and cause a weak spot and a failure on the deck. May be it might be time to swap and move up. You have many options consider! /forums/images/graemlins/confused.gif Guess it's time to go shopping!! /forums/images/graemlins/grin.gif
What would this mower be worth if I was to sell it "as is"?
2019 TAKEUCHI TL10V2 SKID STEER (A52709)
2019 TAKEUCHI...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
KENWORTH T/A DAY CAB ROAD TRACTOR (A57192)
KENWORTH T/A DAY...
2016 Chevy Traverse SUV (A56859)
2016 Chevy...
2017 WEILER P385 ASPHALT PAVER (A52709)
2017 WEILER P385...
2015 CHEVROLET SILVERADO 2500 (INOPERABLE) (A58214)
2015 CHEVROLET...
