JOHNTHOMAS
Super Member
- Joined
- Apr 14, 2008
- Messages
- 7,719
- Location
- Somerset, Ky
- Tractor
- F2690 4WD RTV X1140 MX5400 HST ZD1211
The pasture is a rolling ground. EVERY single low point in the "roll" has water flowing down it, or at minimum has water on top of the ground. I've got a driveway going to go thru 3 of those rolls. My concern is water building up on the uphill side during a daylong rain, and causing cuts below the culverts, because of the focus the culverts will cause. Also if the rain is hard enough, it could build up, uphill of the culverts and wash up over the drive.
What you describe with the plow is kind of what is already there. That's why I was thinking of putting field tile in the bottom of these rolls to let the water run off faster, and be drier before any such rain.
I live on a hillside but I'm not on the top soooo water runs down the hill and across my land. Was a Bad thing for years until I got good stand of weeds mixed with some grass to slow the water some to keep it from making dirt ditches. I now am diverting some of the water to go down more of my yard that is more grass than weeds. I've also planted some grasses that grow quick and thick which will divert some of the water to slow it down. Also have planted several fruit trees and decorative trees and some pecan trees that all need the extra water which was a bad thing but is now a good thing. I have some big patches of grass that grow thick and green due to their extra supply of water. Some places around here use big rock to slow water down and I guess make like dry gulches which can be attractive. I'd make a few dams and have me a small pond or two on mine but I don't get enough water to keep them filled. Every type terrain has some up sides and down sides.Good luck on your water diversion projects. Is you big pond at the bottom where your catching that running down water?
