Kubota F series tachometer
   / Kubota F series tachometer #1
Gkk20011
Milledgeville, GA
Kubota L3800
I have the F3680 and want to add a tach. Techs were an optional factory or dealer add on and so my first choice is the OEM before opting for after market. I have not been able to find the Kubota tach so far.
Maybe someone knows, is a tach optional on the newer F series mowers? That would probably be the best fit. Has anyone gone down this route of adding a tach after the fact.? Any thoughts?
I think I found my answer. Kubota does offer the tach on the new F mowers as an option but at $293 according to the build it page. Ouch. I don稚 think I need one that bad. I am considering an after market called Tiny Tach.
Any thoughts or experience?
   / Kubota F series tachometer #3
Fine if you want one but I don't really see the point?
Either it its idling, running flat out to the governed max speed when mowing, or anywhere in-between when just transporting.
Would you mind elaborating?
Well, the more data the better. I agree when things are running correctly a number is not needed. But if things begin to not run correctly it could serve as a warning or heads up to let you
know to do some preventative service. They were offered as an option so obviously some people must have seen value in it. I can see value but obviously at a price point. like everything.
CATERPILLAR 299D SKID STEER (A51242)
CATERPILLAR 299D...
2007 Ford F350 Super Duty (A50514)
2007 Ford F350...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2017 Freightliner Cascadia 125 Single Axle Sleeper Cab Truck Tractor (A50323)
2017 Freightliner...
Quick Attach 6' Snow Blade (A50515)
Quick Attach 6'...
2019 VOLVO VHD84F300 TRI-AXLE DUMP TRUCK (A51222)
2019 VOLVO...
