Kubota engine cooling problems
   / Kubota engine cooling problems
I cranked it up yesterday and drove it all over the yard without the cap on. The radiator was bubbling a little bit and flowing, but not overflowing at all. I think the bubbles were forming from me hitting bumps.
Weird thing is i could not get it to heat up even close to redline. I drove it all over with the blades spinning. Not sure whats up with that. Might be because it wasnt hot and the grass wasnt tall enough to put much of a load on it.
I installed the smaller battery after this and im going to cut the grass on saturday and see how it does. It should be hotter on saturday so I will get a true test.
   / Kubota engine cooling problems #42
The battery pictured is WAY too big and too close to the radiator, no way for enough air to get through there, I see you got a smaller battery, hope you made sure the radiator fins are clean when you had the battery out, that and the new radiator cap will probably fix it unless it has been run hot too many times and blown the head gasket, I doube that's happened, they are pretty tough little engines. Let us know when you find the fix, I had a G5200 and it was an early '84 so I would bet yours is at least 20 years old, at $600 you got an excellent buy.
   / Kubota engine cooling problems #43
One other thought.. that overflow hose under the rad cap - where does it go, and is it clogged?
I did use compressed air to blow out the fins on the radiator. i was able to examine all of them up close and they are pretty dang clean, just some dust came out. Its getting a radiator flush this weekend before I mow too.
I didnt check the overflow tube for clogs yet. It hangs down about halfway and drips down to the mower deck.
The new battery sits about another 1" further back and an 1 1/2" narrower. I pushed it all the way back and strapped it down good. Im going to post some more pics tommorrow of everything.
   / Kubota engine cooling problems #46
The overflow tube on mine hung down almost to the bottom of the radiator and there was a plastic piece on the end of it that whistled when the the tractor got hot and the pressure went past the radiator cap and out the overflow tube, never had mine overheated, but blew on the other end of the tube one time and it was a whistle to let you know when it was hot.
   / Kubota engine cooling problems #47
A lot of people have made good suggestions and I would like to add just a couple. Two more ways to test for a leaking combustion into the cooling system. Take off the coolant pump drive belt then remove the upper radiator hose from the radiator. Tilt the hose upwards then fill with water to the top. Start the engine then look for bubbles. On V type engines you can isolate the leaking head by removing the sparkplugs or injectors then remove the rocker arms so the valves are closed. Next, remove the schrader valve from the compression gauge hose then apply shop air to the cylinder. This way you can determine which head or cylinder is leaking by looking for the bubbles in the hose.
A friend of mine had a Kubota mower and had taken it to the shop and done all sorts of things. Finally by chance he noticed there was too much oil in the crankcase. He put the correct amount in and wa la, no more overheating.
   / Kubota engine cooling problems #48
One other thing about the coolant mix ratio under 50/50 is designed to keep your metal parts from corroding. However the coolant itself may be old and worn out or of mixed types (Green and orange). I had a truck at work have all kinds of issues because one of the drivers mixed types of antifreeze. After a complete flush and new fluid, all was well. One other observation is you mentioned the thing never overheated when you drove around with the cap off. Bad or incorrect cap???
   / Kubota engine cooling problems #49
BMXer,
Let's back-up a moment, as you said you drove it around, with baldes spinning, and you couldn't get it to overheat.
From the last time it DID overheat, what have you done?
Sometimes when we start fiddling with things, we fix the problem, but don't realize that we did.
I suggest getting some paper and a writing stick.
Make two columns, first column is for any Action you take, like changing the battery. Second column, next to it, is for your observations, did it overheat?
Another thing is to note the ambient temperature outside each time you test it. if it overheats when it's 90F degrees, but not when its 75F degrees, that might point toward airflow issues. So, just be mindful of air temp changes, and any changes you make that may affect your problem.
I agree with Volfandt's and others posts about making sure you check for water pump and thermostat operation. Sorry that I mentioned the compression check, my mind was racing ahead as I thought about an engine that had been continually over heating, but, as eveyone has posted, there are plenty of simpler ways to check for a bad head gasket. You don't want to pull the injectors if you don't need to. Most importantly, we don't want to compound or create other problems along the way. ;)
Sounds like you have changed to the smaller battery, or are ready to, so, just make that note, and do another OverHeat test, to see if you affected the machine.
If it doesn't overheat with the smaller battery, you may well have found your problem.....but, I'd put that Big Battery back, to prove 100% that was certainly the problem.
So, back to the question, when you drove it around and it DID NOT overheat, what was different? Had you moved the battery? Changed coolant levels, blown out radiator...etc etc etc????
Keep us posted, I think you are going to find it this weekend!
   / Kubota engine cooling problems #50
Here is a classic example of being able to prove the trouble!
If it did NOT overheat with the cap off, then place the cap back on, and see what happens? If it overheats, could be the cap...or a related coolant problem.
2025 SDLANCH SDLE20 MINI EXCAVATOR (A58214)
2025 SDLANCH...
Sakai SV505 Vibratory Roller (A53317)
Sakai SV505...
2017 Ford F-550 Crew Cab Enclosed Service Truck w/ Liftgate (A56858)
2017 Ford F-550...
2017 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
202476 (A54757)
202476 (A54757)
2006 GEA Westfalia Separator CA 501-00-32 Two-Phase Decanter Centrifuge (A56857)
2006 GEA Westfalia...
