Kubota D722 Loss of Power
   / Kubota D722 Loss of Power #1
Calhoun Louisiana
Kubota L3430
I have a grasshopper ZTR with a 21 hp kubota deisel industrial engine model D722. I'm having a problem with the motor losing power for usually 2-3 seconds and then building back up. Sometimes it loses power for 5-10 seconds and then builds back up and then sometimes it loses power and in ~10 seconds dies. It's been doing this essentially since I bought it used about 5 months ago but seems to be getting worse. These episodes occur every 10 to 15 minutes but are more frequent when the mower is hot. Otherwise the mower mowes/runs fine. The filter is a paper cartridge type and it was in good shape but I cleaned it anyway. This sounds like an intermittent loss of fuel. There is a fuel cut of solenoid that could be going bad or else not getting it's signal to stay actuated to allow the fuel to continue to flow or maybe there is a pump problem. Does anyone have any thoughts? I will post this on the mower forum also.
   / Kubota D722 Loss of Power #2
Fuel filter most likely needs replacing.
-Fordlords-
   / Kubota D722 Loss of Power #3
Did you get your engine working, cause I'm having same problem. Already chg'd filters - - was wondering about fuel pump
   / Kubota D722 Loss of Power #4
I have similar problem and curious what you all discovered. I replaced both fuel filters (pre and main). Runs great for 45 min, the bogs down. Could it be pulling a vacuum in the gas’s tank?
   / Kubota D722 Loss of Power #5
Do these have a small electric fuel pump? If they do is it working?
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
Bryant 650AN048-E A/C Unit (A52377)
Bryant 650AN048-E...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
