Kubota Common Rail Engine Test Stand/Bench
   / Kubota Common Rail Engine Test Stand/Bench #1
Branden Fischer
SVL95-2
Hello everyone, I have a bunch of kubota common rail engines ranging from the 1803CR to the V3800CR. I need a way to test run these engines before wasting time putting them into a machine just to find some issue. I understand I would need a custom wiring harness and the ECM, has anyone tried this and have some schematics or things you can tell me on how to go about doing this? Do I need a custom ECM? Or can I just use the ones I have, the engines ECM would be deleted to lessen the clutter on the stand so It will just need power to the other parts.
Thanks, Brandon
   / Kubota Common Rail Engine Test Stand/Bench #2
Hi Brandon! Testing those Kubota engines sounds like a great project. You can often use the existing ECMs, but you might need to reprogram them depending on your setup. For the custom wiring harness, check out online forums or groups dedicated to Kubota engines; they often share useful schematics. Good luck!
iq test free online
   / Kubota Common Rail Engine Test Stand/Bench #3
So how does he use the existing ECMs when he doesn't have the existing ECMs? I think that was his question.
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
WATER TRAILER (A58214)
1992 Norris Long Basket Trailer (A60460)
1992 Norris Long...
1999 CHEVROLET C7500 UTILITY TRUCK (A59575)
1999 CHEVROLET...
2018 FREIGHTLINER CASCADIA SLEEPER (A59575)
2018 FREIGHTLINER...
Peterbilt 377 Semi-Truck (A56438)
Peterbilt 377...
