Canopy Kubota canopy
/ Kubota canopy #1
Clammer
Eastern Long Island (NY)
Kubota BX 22
while watching the front bucket and watching the backhoe, I forgot to watch the upper canopy and hit a branch...no booze involved... I cracked the canopy. I took the canopy to a body shop but they can't do anything. The glue won't stick to it. It must be some special kind of plastic that Kubota found someplace. Anyone got any ideas short of buying a new canopy?
/ Kubota canopy #2
Most plastic materials need to be joined with a solvent that "welds" them together. Pick up your Yellow Pages and find a local plastics supplier. They can undoubtedly help you out. Do be aware that these solvents require care to be taken when you are using them, including a respirator, eye protection and gloves of an appropriate material to protect you.
/ Kubota canopy #4
</font><font color="blue" class="small">( ...wonder why the body guy didnt think of that. )</font>
'Cause he's a metal man. Any plastic? They just replace it.
/ Kubota canopy #5
How bad of a crack? if it's not bad you could stop drill it and fill it. i might even think about fiberglass or use a epoxy called dp805 by 3m products. you can get it at industrial supply stores. i would think about using a backing plate of plastic to give the area extra strength.
As said you could try plastic welding it i just don't have alot of experience in that.
you can also sew it . drill a series of holes along the crack and sew with safety wire. i have repaired many plexiglass windows this way in the military on helicopters.
but we really need to know just how this crack looks.
2018 GMC Sierra 2500HD 4x4 Pickup Truck (A66736)
2018 GMC Sierra...
2017 HINO 338 REFRIGERATED 26FT CDL REQUIRED BOX TRUCK (A69167)
2017 HINO 338...
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
2019 Westinghouse WSTBT1503 Wireless Speaker (A61574)
2019 Westinghouse...
500 BBL WHEELED FRAC TANK (A67714)
500 BBL WHEELED...
2023 JCB 3TS8T Teleskid High Flow Compact Track Loader Skid Steer w/ 7 Ton Gooseneck Trailer (A66734)
2023 JCB 3TS8T...
