Kubota BX2750 front mount snowblower on a Kioti CK35
   / Kubota BX2750 front mount snowblower on a Kioti CK35 #1
fbeach73
Fredericton,New Brunswick
2014 Kioti CK35
Does anyone know if this snowblower is compatible with my tractor? See this listed locally for sale second hand and asking price is 2000$... its a 50" but im not familiar with compatibilities
thanks a lot!
   / Kubota BX2750 front mount snowblower on a Kioti CK35 #2
Not sure if it will fit. I have a 52 inch on my ck20 and it barely covers my tire tracks. I would think a 50 is way to small for yours.
   / Kubota BX2750 front mount snowblower on a Kioti CK35 #3
Will the MM driveline fit? You most likely will need to modify the front quick attach to fit your ck frame. Do you know how to do metal fabrication?
   / Kubota BX2750 front mount snowblower on a Kioti CK35 #4
I don't think it will fit, the CK is quite a bit wider than that, close to 60". Also, The CK35 is a whole lot bigger, almost in a different class than the B, I would think you would need to do some serious modification to get it to fit. The mounting system most certainly would have to be modified.
   / Kubota BX2750 front mount snowblower on a Kioti CK35 #5
The ck35 with r4 is just under 64" wide at the rear. I don't think you will be happy with a 50" blower.
2018 Infiniti QX60 SUV (A51694)
2018 Infiniti QX60...
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
New/Unused AGT YSRT14 Mini Skid Steer Loader (A51573)
New/Unused AGT...
2019 John Deere S780 Combine (A53342)
2019 John Deere...
Landoll Hauloll (A53472)
Landoll Hauloll...
