Kubota BX2750 front mount snowblower on a Kioti CK35
   / Kubota BX2750 front mount snowblower on a Kioti CK35 #1
fbeach73
Fredericton,New Brunswick
2014 Kioti CK35
Does anyone know if this snowblower is compatible with my tractor? See this listed locally for sale second hand and asking price is 2000$... its a 50" but im not familiar with compatibilities
thanks a lot!
   / Kubota BX2750 front mount snowblower on a Kioti CK35 #2
Not sure if it will fit. I have a 52 inch on my ck20 and it barely covers my tire tracks. I would think a 50 is way to small for yours.
   / Kubota BX2750 front mount snowblower on a Kioti CK35 #3
Will the MM driveline fit? You most likely will need to modify the front quick attach to fit your ck frame. Do you know how to do metal fabrication?
   / Kubota BX2750 front mount snowblower on a Kioti CK35 #4
I don't think it will fit, the CK is quite a bit wider than that, close to 60". Also, The CK35 is a whole lot bigger, almost in a different class than the B, I would think you would need to do some serious modification to get it to fit. The mounting system most certainly would have to be modified.
   / Kubota BX2750 front mount snowblower on a Kioti CK35 #5
The ck35 with r4 is just under 64" wide at the rear. I don't think you will be happy with a 50" blower.
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
2014 DITCH WITCH RT45 RIDE ON TRENCHER (A51246)
2014 DITCH WITCH...
