kubota bx25
/ kubota bx25 #1
thelegendvaslett
Terrenceville
kubota bx25
I have a kubota bx25 she stalled on me yesterday and could not get it going again, I have fuel stabalizer in it and stuff. my brother in law came I tried to put a hairdryer on the fuel filter but it still was too cold, I put it in neutral and my father in law toed me up to my house. warmed up charged the battery and now when I try to start it is not starting it lights up but wont crank over, Checked the pto lever and wiggled it trying to start it and also the switches under the seat, all worked fine before this happened, One thing the pedals feel a little tight when I press down on them just noticing it any help would be greatly appreciated.
/ kubota bx25
If you are on the seat the parking brake has to be engaged. If that is not it you need to start jumpering all the interlocks to find the culprit. How many hours, time has a way of creating gremlins.
Ron
Sorry for not getting back to you sooner been very sick with the flu?? this one can start in gear callled the dealer they said it could be the switch under where the pedals are went out and got wet trying to move the pedal to the neutral postion without and luck. I have one switch taped down and the other one (grey) goes down with the seat I also tried the pto lever to make sure it was back all the way without any luck all I get is everything lighting up and the fuel pump kicking over with a clicking noise wont turn over up to my wits end here.
/ kubota bx25 #5
pedals may not be 'centered' and keeping that safety switch from allowing you to start.
I do plan to adjust my PTO switch it's a hair trigger and annoying.
2003 Kenworth W900 L Model (A62613)
2003 Kenworth W900...
New Westinghouse Generator (A62613)
New Westinghouse...
2020 Kawasaki Mule Pro DXT (A62613)
2020 Kawasaki Mule...
Ford 8N Tractor (A66408)
Ford 8N Tractor...
2018 Cat D6T LGP VPAT Dozer (A62679)
2018 Cat D6T LGP...
2015 FREIGHTLINER CASCADIA T/A DAYCAB TRUCK TRACTOR (A59914)
2015 FREIGHTLINER...
