Kubota BX24 MMM Question
   / Kubota BX24 MMM Question #1
Woodsmoker
Boyce, VA
BX24
Is there a way to "lock" my MMM in the up position so I can use the 3pt hitch without raising/lowering the deck at the same time?
   / Kubota BX24 MMM Question #2
on my 1800 the height known had a TOP setting on it
   / Kubota BX24 MMM Question #3
As per chucko, there is a way. Raise your deck all the way to the up position and hold it here a bit and you should then be able to rotate the knob to TOP and it will stay in the raised position while you use the 3PH.
   / Kubota BX24 MMM Question #4
It is hit or miss on my bx24 with moving to locked...PITA at times.
   / Kubota BX24 MMM Question #5
well- its not a hit of miss.. since its a one way turn, I just slow down when I approach number 4 cutting height and click one at a time. never miss this way.
   / Kubota BX24 MMM Question #6
Sorry, your method does not work. It gets to the #4 and that is it, no click one time..
My old bx22 never had an issue, this one grrrrrrrrrrrrrrrrrrrrrr.
   / Kubota BX24 MMM Question #7
:confused3: I dont know what to tell u- i dont have a problem doing it that way.... I guess its a different strokes for u .:(
   / Kubota BX24 MMM Question #8
There are some other threads on here dealing with this with suggestions on adjusting the lift linkage. I had to have it done on my 2200.
   / Kubota BX24 MMM Question #9
You need to adjust the MMM linkage. The lift rod for the MMM connects to the top left (from behind) 3PH lift arm - just inside the top of the left rear wheel. There's a threaded bolt with a lock nut on it. Loosen the locknut (the inside nut), then adjust the threaded bolt so the MMM lifts a little higher. Done!
Had this issue on my old BX1860.
   / Kubota BX24 MMM Question #10
Thanks..Have to take a look into that tomorrow since it driving me nuts!!!!!Almost as bad as the pins, installing to frame, on the BH...
I miss the old 22 at times like these.
2015 F-550 Bucket Truck Gas Engine (A52128)
2015 F-550 Bucket...
1985 Ford Ltl9000 Tender Truck (A52128)
1985 Ford Ltl9000...
1994 FORD F450-SUPER DUTY FLATBED (A51219)
1994 FORD...
2002 Wilson Hopper Bottom Trailer (A50514)
2002 Wilson Hopper...
2000 Ford Ranger (A50515)
2000 Ford Ranger...
1997 Mercedes Convertible (A48082)
1997 Mercedes...
