Oil & Fuel Kubota BX2360 choking up in the cold
   / Kubota BX2360 choking up in the cold #11
You may want to check the filler cap. I do believe it should be vented. If it can't suck in air as you use fuel it could cause a problem. Moisture could be plugging the vent when temps drop. It's an easy check, just loosen it the next time you have the problem and see how it runs.
   / Kubota BX2360 choking up in the cold #12
JWR is right. OR, if you can get heat onto the fuel filter, it could keep it from gelling, or run up to 50% kero. Had gelling one time in 39 years of running diesel cars. That was one morning at -22 F in Vermont. Started up fine with lower radiator hose heater run for about 20 minutes. Drove down the road, and it stalled. Let sit a minute or two. Restarted. Drove down the road another mile or two. Quit. Same thing. Finally ran without stopping. Big fuel filter on a Benz is right next to the engine block. There is a tiny pre filter, similar to those silly ones big American V8s had upstream of their carbs. It never plugged.
Ralph
   / Kubota BX2360 choking up in the cold #13
In most northern places there is a summer diesel and a winter diesel supplied by the distributors. The suppliers will switch between the two as per the season.
   / Kubota BX2360 choking up in the cold #14
That is what is SUPPOSED to happen. The problem is the user filling his tank has no reliable way to know whether the distributor did the winterization or not. If he did, how much and how far down is it good for ? Where does brand A executive sitting in some office tower deciding fuel distribution policies think the border is between 'northern places' and non-Northern places? Depending on distributors winterizing fuel is a form of Russian Roulette. I've had the exact same experience as RalphVA describes above.
What works every time is to check the temperatures/forecast and if it may go below about 12 or 14 degrees F, then mix in some kerosene, up to 50%. What works some of the time is buy into the myriad varieties of additives. What stands an unknown % risk of stalling out with gel is to depend on distributor winterization.
   / Kubota BX2360 choking up in the cold #15
Up in the frozen north I've never had a fuel gell issue with filling station Diesel.
   / Kubota BX2360 choking up in the cold #16
Glad you have not had the problem. There was no bullet in your chamber when the trigger was pulled. Very likely the fuel distributors are keen on the issue in places like Nova Scotia. It is very possible that fuel distributor practices have improved too.
I have had the problem (automotive diesels) in Troy VT near the Quebec border (at around 10 below zero F) and in West Virginia going over a mountain where the temp dropped below around +10 deg F.
How far down in temp will the filling station fuel protect you ?
   / Kubota BX2360 choking up in the cold #17
I also NEVER had a problem for several years until this winter. With the Racor setup and the clear fuel bowl, you could see the problem. That was with an additive. Mine was gelled up so bad I pretty much had to change the filter. I'd say JWR is spot on with his ideas. Additives help, but how much?
   / Kubota BX2360 choking up in the cold #18
Lowest I filled up was -45C. Happened more than once too.
   / Kubota BX2360 choking up in the cold #20
I disagree completely. I assume you meant "below zero" as below zero F and more than 17 below Centigrade ? If YES, continue reading what I am about to say. If NO forget my comments here. The symptoms you describe are typical of diesel fuel gelling. Not actually "freezing." It is guaranteed to happen at zero F and I have seen it at about 11 deg F. with an automotive diesel. The warmth from running it a short time, being inside a closed place no matter heated or not, probably loosened up the fuel flow. This fits perfectly with a case where you had added an additive recommended by the dealer (!) and you were right on the edge of more serious gelling. It is also a perfect illustration of why I claim that additives are only a marginal solution that help in a limited way and DO NOT fix the problem with any certainty. Additives are just a maybe of a fix. Most of us do not want a Maybe. I have said in many posts that the real and certain fix is to mix #1 fuel (kerosene) with your normal diesel #2 fuel in a 50-50 mix. I repeat one more time, this is exactly what the heavy equipment operators do in northern VT and NH and places with climates similar to yours. In the very cold weather, just run half kerosene. It will hurt absolutely nothing. The lube qualities are only slightly degraded and that for a relatively short time. Your power output will be reduced by a tiny % and you will NEVER notice either of those 2 side effects. By the way, your experiment essentially shows how much the additive lowered your gelling point (or rather how far it did NOT lower the gelling point.) Lowered it some, just not enough. The additives won't hurt anything but if you really want a reliable solution, mix in the kerosene. I do not have the numbers but ask your local heavy equipment operators -- they can tell you how far below zero F the 50-50 mix will cover you.
By the way, there is no reason at all to get into these messy (and potentially problem causing) screwing with filters. Once the engine is warmed up running on a usable mix of fuel for a while the gel will be "disolved" in the various filters. Only if it was so bad you could not get it to run at all would screwing with filters be warranted. Even then it would be better to just move it to a warm place for a few hours. Good luck and let us know how this all came out.
Even in Western Washington state where temps do not get extremely low I used to mix a 50/50 #1 and #2 fuel for our diesel fuel fire station APU's that sat in the open. Although maybe every 30 years we get down to 0 degrees F, I did not want to have to deal with any fuel issues at that time should the rare north front happen. Power output may have been reduced a tad but it sure beat the alternative.
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A48081)
2013 Crane Carrier...
2011 JACK  130BBL (A48992)
2011 JACK 130BBL...
Ripper Tooth (A47371)
2000 Toro Workman 3200 Utility Cart w/ Body Mounted Hydraulic Scissor Lift (A46684)
2000 Toro Workman...
2020 MacDon C3008C (A47164)
2020 MacDon C3008C...
BANDSAW W/ ROLLER TABLE (A48992)
BANDSAW W/ ROLLER...
