Kubota BX2350 power issue
   / Kubota BX2350 power issue #1
bkusich
Freedom, PA
BX2350
My Kubota has just over 300 hours on it. It starts fine, but when I depress the gas pedal, the engine stops. I have changed both fuel filters, the oil filter and the air filter. Any suggestions?
   / Kubota BX2350 power issue #2
bkusich,
When you turn on the key, but before you try to start, do you hear the electric fuel pump clicking?? If hot, it has failed. I had that happen to mine at about 150 hrs. I replaced it with an aftermarket one, as the one from Kubota was over $250. Got one from Auto Zone for $50. I don't recall the name or model of it. I have had no problems after the change.:2cents:
Dave
The fuel pump is clicking. So I tried pulling the seat to check for any failed sensors. There was a loose connection and a broken spring. I fixed both and now it works. It's funny how such a small thing can cause such an issue. Thanks, Dave, for the comment. Much appreciated.
   / Kubota BX2350 power issue #4
Me being a "light weight", I had to disconnect and jumper the seat switch connector. It kept trying to shut off the motor when I would hit a bump while moving. 2 inches of wire and 2 quick connectors later, NO PROBLEM. :D I'm sure you will get lots of good seat time with your BX.
Dave
   / Kubota BX2350 power issue #5
Thanks for these posts as it is good thing to know about the fuel pump click and some failing so quickly and the after market ones being so much cheaper . I don't know if I have a sensor under the seat of my B2650 or not as I can get off the seat with the tractor still going maybe it only activates when the pto is on .
   / Kubota BX2350 power issue #6
HEC,
It should turn off the engine IF the PTO is engaged OR the brake is not set.
Dave
   / Kubota BX2350 power issue #7
HEC,
Dave
Thanks Dave as it must not be hooked up as it doesn't matter if the brake is set or not as the tractor will still run on the 2650 . I am not sure about the pto though .I would guess my 2005 M5700 doesn't even have a shut off , it does give off a buzzing noise when you get off the seat and the pto is on .
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A52748)
2023 New Holland...
2017 JLG 1932R 19ft Electric Scissor Lift (A50322)
2017 JLG 1932R...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
NEW Fork Extensions (A53002)
NEW Fork...
Grundfos Vertical Pump (A50121)
Grundfos Vertical...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A52748)
2020 New Holland...
