Kubota BX2350 Mid hydraulics arms not lowering
   / Kubota BX2350 Mid hydraulics arms not lowering #1
bx2350 owner
DFW, Texas
Kubota BX2350
Guys....thanks for letting me be a part of the forum that has helped me many times with previous machines!
I just bought a used BX2350 with low hours. I had to transport the machine and removed the 60" MMM and the arms raised and lowered at that time. I just completed all of the 50 hour service (although the tractor has more hours than that) just to be sure everything was fresh. I replaced the hydraulic fluid and filter, checked and cleaned the screen, changed the oil and filter and both fuel filters. I also drained the front axle fluid and replaced that. I have double checked everything and all is working. The only place I was really close to any lines was with the second fuel filter underneath and I have triple checked that I didn't damage anything close. The rear 3pt. work fine...just the mid arms won't move for me to replace the deck. Any ideas?
   / Kubota BX2350 Mid hydraulics arms not lowering #2
Hello. It sounds like the hydraulics are fine if the 3 pt hitch is working normally. Have you checked the mower height knob? It may be set to "Top" which would cause the mower lift arms to stay up.
   / Kubota BX2350 Mid hydraulics arms not lowering #3
That or (less likely) there is something jammed in the height mechanism underneath.
Aaron Z
2014 Yale 3 stage 8500lbs lift solid tire forklift (A53472)
2014 Yale 3 stage...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A53472)
2022 New Holland...
2017 E-Z Beever M12R Towable Brush Chipper (A51691)
2017 E-Z Beever...
2020 JOHN DEERE 8R 250 LOT NUMBER 185 (A53084)
2020 JOHN DEERE 8R...
2023 AGT Topcat Stump Grinder (A51573)
2023 AGT Topcat...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A53472)
2021 NEW HOLLAND...
