Kubota BX2350 Mid hydraulics arms not lowering
   / Kubota BX2350 Mid hydraulics arms not lowering #1
bx2350 owner
DFW, Texas
Kubota BX2350
Guys....thanks for letting me be a part of the forum that has helped me many times with previous machines!
I just bought a used BX2350 with low hours. I had to transport the machine and removed the 60" MMM and the arms raised and lowered at that time. I just completed all of the 50 hour service (although the tractor has more hours than that) just to be sure everything was fresh. I replaced the hydraulic fluid and filter, checked and cleaned the screen, changed the oil and filter and both fuel filters. I also drained the front axle fluid and replaced that. I have double checked everything and all is working. The only place I was really close to any lines was with the second fuel filter underneath and I have triple checked that I didn't damage anything close. The rear 3pt. work fine...just the mid arms won't move for me to replace the deck. Any ideas?
   / Kubota BX2350 Mid hydraulics arms not lowering #2
Hello. It sounds like the hydraulics are fine if the 3 pt hitch is working normally. Have you checked the mower height knob? It may be set to "Top" which would cause the mower lift arms to stay up.
   / Kubota BX2350 Mid hydraulics arms not lowering #3
That or (less likely) there is something jammed in the height mechanism underneath.
Aaron Z
2021 Redirective Crash Cushion Guardrail (A51692)
2021 Redirective...
2023 CATERPILLAR 299D3 SKID STEER (A51246)
2023 CATERPILLAR...
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1ET4EKG11918 (A51572)
2014 Ford F-150...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
KUBOTA M7-132 (A53084)
2011 JACK  130BBL (A52472)
2011 JACK 130BBL...
