KUBOTA BX2230
   / KUBOTA BX2230 #1
redneckarchery.com
I HAVE A BX2230 WITH 275 HOURS ON IT AND NOTICE SOME FLUID LEAKING AFTER DOING SOME VIGOROUS BUSHHOGGING. TRAILER IT AND BROUGHT IT HOME AND DECIDE TO GO AHEAD AND REPLACE THE FLUID AND FILTER SICE IT WAS GETTING CLOSE. THEN I REMEMBERED THAT I HAD DONE REPLACED THE FLUID AND FILTER AT ABOUT 150 HOURS WHEN SOMETHING PUNCTURED MY FILTER. SINCE THE FILTER WAS NOT THAT OLD I DECIDED TO LEAVE IT ON. AFTER REPLACING THE FLUID IT STILL LEAKS BAD. I CAN CUT GRASS FOR 30 MINUTES AND HAVE A 8" PUDDLE AFTERWARDS. I HAVE CHECKED THE VENT TUBE ITS FINE. I HAVE CHECKED THE STRAINER AND ITS IS FINE.
COULD SOMETHING BE IN THE OLD FILTER THAT IS MAKING IT LEAK THIS WAY. LOKING FOR SOME POINTERS HERE IF ANY OF YOU HAVE RUN ACROSS THAT BEFORE.
THANKS
   / KUBOTA BX2230 #2
This is a double post.
2009 IC Corporation PB105 Passenger Bus (A51692)
2009 IC...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A52748)
John Deere 6105E...
2013 Nissan Pathfinder SUV (A51694)
2013 Nissan...
2013 KENWORTH T800 TRI AXLE CRANE TRUCK (A52472)
2013 KENWORTH T800...
City of Buckhannon -Onan 50 Set Stand By Generator (A52384)
City of Buckhannon...
2011 Crown Victoria Sedan (A51694)
2011 Crown...
