Kubota BX2200 loader will not go up or down
   / Kubota BX2200 loader will not go up or down #21
It has nothing to do with the couplings, hoses, or cylinders. With what has been described, it is in the float detent assy. Even if you disconnect the lever linkage from the spool, you will not be able to remove the spool and detent assembly without removing the detent cover screws first. Then the spool and detent can be pulled rearward from the valve block (manifold as you call it).
2004 Thomas Bus (A57148)
2004 Thomas Bus...
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
Teakwood Horse Stool (A57454)
Teakwood Horse...
2014 John Deere HPX Gator (A57149)
2014 John Deere...
2020 Kubota SVL 95-2S Skid Steer (A57148)
2020 Kubota SVL...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
