Kubota BX2200 HST Shudder - Barely Moves
   / Kubota BX2200 HST Shudder - Barely Moves
Aaron,
Thanks for the suggestion. I have not done that - I don’t see any frothing or anything, but that sounds like something worth I try before I tear into it.
Thanks!
Tom
Hello All,
Thank you for your responses. I thought I would provide an update to hopefully help people in the future.
After I determined my charge pressure was low, and tried all the quick fixes (new filters, cleaned strainer, bleed air, etc), I still had no luck. I ended up picking up a lightly used HST online. I installed it (took about 4 hours to get everything apart and 6 hours to get everything back together). Also cleaned and put new boots on the propeller shaft joints and replaced the fan. I would recommend doing these things as they are cheap and easy while you have everything apart.
Once I got everything reassembled, I checked the charge pressure and it was back within spec.
Long story short, it looks like the problem was internal to the HST. I am going to tear down the old one to see the exact failure mode when I get a chance. My suspicion is that the unit got too hot; the fan was intact but there was a ton of mud and dirt caked on the HST, so I知 sure the heat transfer was not very good.
Overall wasn稚 a bad job...much easier than it looked. The hardest parts were a few spring pins that were corroded in place. Other than that very manageable DIY project.
Thanks,
Tom
   / Kubota BX2200 HST Shudder - Barely Moves #13
I was wondering where you found your used transmission? I have a bx2200 with very similar issues.
2013 FREIGHTLINER BUSINESS CLASS M2 VACUUM TRUCK (A51406)
2013 FREIGHTLINER...
Chevrolet Silverado 1500 (A52377)
Chevrolet...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
1993 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
1993 HEIL TRAILER...
2021 John Deere C12R Corn Head (A53342)
2021 John Deere...
1999 LBT INC FUEL TRANSPORT TRAILER (A52472)
1999 LBT INC FUEL...
