kubota bx2200 cranks but no catch or start what have I overlooked?
   / kubota bx2200 cranks but no catch or start what have I overlooked? #1
maxsanders
GADSDEN
BX2200 l3710
fuel pump delivers fuel to injector pump
solenoid functions ...I removed it and see it works
key and starter ok...interlock for pto and fast/slow seen ok since it cranks
disconnected one injector line,,,it spits what seems a tiny amount of fuel but I dont know what to expect.
Anything else to check? Looks like injector pump?
Many thanks for help over the years.....Best Max
I
Great news....(my oversight) there is water in the fuel and cloudy mix drains from port on injector pump.
Now...is there an easy way to correct this?
Thanks Max
   / kubota bx2200 cranks but no catch or start what have I overlooked? #3
Drain the fuel tank, change the filter, blow out the lines..
Loosen ALL the lines AT THE INJECTORS.. Loosen the inlet line AT THE PUMP..
If it has an electric lift pump on it, it will push the air & fuel out at the inj. pump inlet.. tighten the line after u get clean fuel & no bubbles.
Personally I would leave the electric shut off completely out of the equasion..
Fill the tank w/ MORE THAN 5 gallons.. OF FRESH fuel.. & spin the engine until fuel squirts out of the loosened injector lines..
Tighten the lines & off u go..
BTW> Have the throttle WIDE OPEN when bleeding & starting..
   / kubota bx2200 cranks but no catch or start what have I overlooked? #4
Also check the stop solenoid, make sure it's releasing again after shutting off. I just had to replace the one on my 2009 BX. It would let go if I fiddled with the throttle or touched the part itself, but otherwise turning off the key sucked it in and it wouldn't let go.
2014 Ford Escape (A50323)
2014 Ford Escape...
2019 Freightliner 122SD, Cummins X15 (A52384)
2019 Freightliner...
2018 Chevrolet Tahoe SUV (A50324)
2018 Chevrolet...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A52748)
2017 Yale GLC050VX...
Truck Front End w/ Cat Engine (A50121)
Truck Front End w/...
2017 TOYOTA TUNDRA(INOPERABLE) (A52472)
2017 TOYOTA...
