Kubota BX220 problem
   / Kubota BX220 problem #11
Charliebrn,
3. Remove the deck. This is a little tricky, as the fenders want to be in the way, but if you've loosened them, they'll move enough for you to wiggle the deck off.
My BX has had the sticky HST problem from day one.
It did not have a "factory" installed grease fitting on the side of the HST. /forums/images/graemlins/crazy.gif
Local dealer came out one day and tried to fix it.
Actually, he botched up the job and did not really fix the problem.
He drilled a hole on the side of the petal and installed a fitting.
He installed it crooked and it only held on by a thread or two.
/forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif
I had a very difficult time "greasing it" and not really sure if I ever
got any grease down in there. In fact the first time I went to
add some grease, the fitting popped off! /forums/images/graemlins/mad.gif
Well, the fitting is now long gone, busted it off somehow.
Plan on trying your method.
How do you remove the knob that controlls the amount the MMM lowers?
   / Kubota BX220 problem #12
The knobs pull off. If I remember right, they were on there pretty good and I had to give a good tug.
In my case the dealer finally received a pedal mount with a zirc installed at the factory, but didn't know when he'd get to it, so I installed it myself. Wasn't too bad of a job, and actually learned quite a bit about the tractor. It's a great time to replace the first fuel filter too!!! /forums/images/graemlins/laugh.gif
2020 CAT D6K 2XL (A55272)
2020 CAT D6K 2XL...
2017 Freightliner M2 106 AWD Terex Commander C4047 Insulated Digger Derrick Truck (A55973)
2017 Freightliner...
CATERPILLAR 21" PIN ON BUCKET (A52706)
CATERPILLAR 21"...
Electric Utility Cart (A56857)
Electric Utility...
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55315)
2023 Kubota M4-061...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
