Kubota BX Weight Bracket, etc.
   / Kubota BX Weight Bracket, etc. #1
jcpwrsprt
Go Pack!
Kubota BX2350
Just finished up the modifications to the OEM grill Guard to accept 4 suitcase weights. This will allow me to use 3pt attachments with out the FEL for ballast.
   / Kubota BX Weight Bracket, etc. #2
From a fellow BX owner I gotta say.....NICE JOB!!
Are those kubota weights? or generic?
How many lbs.?
I have been looking at the Kubota weight bracket, which angles downward.
I thought maybe this was so that it didn't conflict with the FEL.
Not that they would be needed, but, does the FEL fit OK with the weights in place??
Also, thanks for the great pics!
well done.
Skunk:
As I'm sure you are aware the OEM weight bracket cannot be used in conjunction with the OEM Grill Guard. This is the reason I decided to Fab something myself.
The bracket itself protrudes 6" out from the frame which is the maximum to accommodate the FEL.
To answer one of your questions: The weights themselves need to be removed before attaching the FEL.
The suitcase weights -- I purchased off E-Bay which was much cheaper than the $60 (each) ouch... Kubota wants for them.
I believe they are Jinma weights 35-37 lbs each
Thanks
-JC
   / Kubota BX Weight Bracket, etc. #4
I was eyeing those Ebay weights, don't know if they are the same ones you used? Set of 4.
I haven't removed my FEL yet, but if I did, I would definately need a front weight set-up. Also figured they could do double duty on a 3PH rig, too.
Not only are the Kubota weights a little pricey as you mentioned, how bout that factory bracket? Ouch!
Again, Nice job, very nice indeed.
2015 Toyota Camry Sedan (A51694)
2015 Toyota Camry...
Cat TH407C Telehandler (A52748)
Cat TH407C...
27ft x 24ft Metal Building (A51573)
27ft x 24ft Metal...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
2010 PETERBILT 340 (A52472)
2010 PETERBILT 340...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
